Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Dodge Ram Decals
Old 07-17-2013, 09:31 PM
Muddy's Avatar
Muddy Muddy is offline
Vehicle: 2013 Ram 1500 Express
Color: Deep Cherry Red Crystal Pearlcoat
Rep:80
Muddy will become famous soon enough
Default Oil filter relocation kits?
Did my first oil change on my 2013 HEMI today. I already knew going into it that the Chrysler guys placed it in a position that would give us all a headache to change the oil ourselves. I did the old milk jug trick so no mess however, I need to move it. So do any of you know of anyone that makes an oil filter relocation kit? I found some for the HEMI but only up to 2010 model year. Even if it is from some shade tree mechanic that you trust making them out of their garage I think it would be worth it for me and my back. And neck, knuckles, elbows, arms, head and everywhere else I received a bruise on today. The fellow below never had a chance. He was not NASCAR approved, refused to turn left.
File Type: jpg 1069258_655047184522724_594286354_n.jpg (34.6 KB, 203 views)
Old 07-17-2013, 10:23 PM
Irv's Avatar
Irv Irv is offline
Vehicle: White 2013 QC 4x4 BigHorn
Trim Level: BigHorn
Rep:14
Irv is on a distinguished road
Although I haven't changed my oil yet to find out for myself what most talk about on here, I too was wondering if there was one available for these Rams?
Definitely interested if one is available or someone decides to fab some up.
Old 07-18-2013, 02:09 AM
HM1 HM1 is offline
Vehicle: 2013 Ram Hemi
Color: Black gold
HM1 is on a distinguished road
There are oil coolers using a filter relocation set up. Pretty cheap for the whole system about $150.
Old 07-18-2013, 06:34 AM
Outdoorsman2012 Outdoorsman2012 is offline
Vehicle: 2012 Ram Outdoorsman
Trim Level: Oudoorsman
Rep:39
Outdoorsman2012 is on a distinguished road
I'll try to find it later for you on etrailer. However it will require a cooler installation as noted above. I installed the Collier and used a sand which valve so my filter is still in the stock location.
Old 07-18-2013, 03:51 PM
maw76's Avatar
maw76 maw76 is offline
Vehicle: 2013 RAM 1500 QC
Trim Level: Outdoorsman
Rep:49
maw76 is on a distinguished road
WOW they put that on with 250 ft/lbs of torque now really not looking forward to my oil change poor knuckles I hate wearing gloves when working on cars even plastic ones just to stay clean.
Old 07-18-2013, 09:30 PM
Rep:39
Derale Plate-Fin Engine Oil Cooler Kit # D15451. I bought the one that has a built in thermostat as I wanted it to keep the oil cooler when towing my TT. I assume you could install the kit I referenced and not have to install the cooler part and only run hoses to where you locate the filter
Old 07-18-2013, 09:52 PM
Irv's Avatar
Irv Irv is offline
Trim Level: BigHorn
Rep:14
Thanks ODM, but since my truck already has the factory oil cooler already installed, I don't really need all that extra stuff.
But if that is the only one currently available, then I suppose you could modify or eliminate some of it to make it work?
http://www.etrailer.com/Engine-Oil-C...le/D15451.html
Just did a quick Google search and it looks like more than one kit exists.
Definitely going to look into one, especially the one posted on Dodetalk.com near the top of this link. TTI I think it is called?
Type in, ram oil filter relocation kit
Old 07-18-2013, 10:30 PM
Rep:39
I have the 2012 outdoorsman QC 4x4, I know stuff may have changed but the outdoorsman package was more of the stock heavy towing package. Came with the 3.92 axle e range tires all the heavy duty cooling. I have the engine oil cooler stock and also the one I installed. I tow a 7420 lb camper and was running 220-230 engine oil temp. I never saw this temp go down once it reached a certain temp pulling a grade it would hold it until the next grade and rise again and hold that temp. This worried me as I thought that it may get to high and the reason I installed the additional cooler. I know run about 180-185 empty and 205 towing. Which is about 20-25 degrees cooler but have still yet to see any temp drop even with the additional cooler.
My kit is the 15405 which keeps the stock location for the oil filter. E trailer even has a video of the install. They seem like a very knowledgeable company. If I were you and no one had anything else was able to help I would ask e trailer if you could buy the cooler but use it only to relocate the oil filter.
If you don't plan on towing anything of that weight I agree that the kit may be useless to you but if you do tow I would really look into installing the cooler also. My truck rarely goes above 3k RPMs towing the trailer so I know its more than capable but I'm starting to venture further out into the big mountains and wanted the reassurance that I could keep things cooler. If I was typically running 4k rpms plus I would know it wasn't the cooler but I've seen 3.5k rpms once and that was with cruise control and it caught me off guard. For towing greater weight I feel the engine oil needs additional cooling. My coolant twmp doesn't really budge and when it does the temps drop quickly. The highest temp the trans has seen was 172 was when I forgot to hit the tow/haul button, once I engaged it temp dropped to low 160s. Hope this info helps
Old 07-19-2013, 12:24 AM
Muddy's Avatar
Rep:80
Thanks, will be my next mod.
Old 07-19-2013, 08:20 AM
2010renegade 2010renegade is offline
Color: Maximum Steel
Rep:28
2010renegade is on a distinguished road
One I found, http://www.tdperformance.com Trans-Dapt Single Filter Relocation Systems
Trans-Dapt introduced oil filter relocation products back in the early 70's. Each kit comes complete with an oil filter bypass adapter, cast aluminum remote OIL FILTER base, oil sending and return lines, pre-installed hose fittings, filter nipples and mounting hardware.
1127 Single Oil Filter Relocation System; 2-1/2" I.D. and 2-3/4" O.D. Bypass Flange w/ 22mmX1.5 Threads 22mmX1.5 2-1/2" 2-3/4"
