Old 07-19-2013, 04:30 PM
BillieD BillieD is offline
Vehicle: 2009 dodge ram
Color: blue
BillieD is on a distinguished road
Default Driver headlight issue - help?
I have a 2009 Dodge Ram 1500 Big Horn edition and am having a problem with a headlight that won't stay on. I replaced both high and low beam bulbs and they work until I hit a bump, then go out again. I can jiggle the wire and they come back on until I hit another bump. Suggestions, please?
Old 07-19-2013, 05:06 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Don't replace anymore bulbs...waste of money.
You are probably moving around the ground wire. You need to see if it is coming out of the plug. Try to push it back in until it clicks. That is going to be your problem if only one headlight is affected. I want to say it is the black with the green strip on the headlight connector.
Chrome... in moderation.
Old 07-23-2013, 09:38 PM
Color: blue
Thank you. I will check it out over the weekend and report back.
Old 08-21-2013, 12:21 PM
dwsdad dwsdad is offline
Vehicle: 2012 RAM 1500
Rep:15
dwsdad is on a distinguished road
Mine problem was the connector at the end of the harness that plugs into the headlight.
Old 08-21-2013, 12:27 PM
bighemi04's Avatar
Rep:623
My stock light has the same problem. Were you able to get a connector from somewhere?
Old 08-21-2013, 04:19 PM
Rep:15
I had the dealer take care of it since it was still under warranty. I'm assuming they have the connector at the dealerships.
