Old 07-09-2013, 03:36 PM
RLabbe RLabbe is offline
Vehicle: 2011 Dodge Ram
RLabbe is on a distinguished road
Default Headlights working Intermittently
Need some help. My passenger side headlights work intermittently. Both low and high beam just go out from time to time, they will both work for a couple days and then they wont for a couple days. I took it to the shop to see if they could find a short or loose connection with no luck but, of course they were working when I brought it in and we couldnt make it duplicate the problem. Even changed the bulbs thinking maybe by some odd coincidence they both burt out at the same time, even though I rarely use my high beams. The driver side lights are both working fine. Any assistance would be greatly appreciated.
Old 07-09-2013, 03:41 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Sure sounds like a ground wire is lose somewhere in the connection on that side.
My passenger side ground on the headlight went out killing the functions of that side(low/high beam).
Chrome... in moderation.
Old 07-09-2013, 04:24 PM
cawish33 cawish33 is offline
Vehicle: 2011 dodge ram
Trim Level: sport q/c
Color: hunter green pearl
cawish33 is on a distinguished road
same here and when i disconnect the connector the 3 little pin was not properly insterted so i take my long nose plier and pull them a bit and reconnect and BOOM problem fix !!
Old 07-10-2013, 12:08 PM
Thanks guys. I'll look into that this afternoon.
Old 07-13-2013, 01:25 PM
Color: green
Rep:657
how did the advice work out for you.
Old 07-17-2013, 01:33 PM
blackpearldodge's Avatar
blackpearldodge blackpearldodge is offline
Vehicle: 2011 Crew Cab 1500 Sport 4x4
Color: Black Pearlcoat
Rep:19
blackpearldodge is on a distinguished road
I had my truck in for servicing for the same issue. The technician ended up cutting out the connector pin (main wiring harness to main wiring harness to headlight assembly). At first I was pissed that he did this. I was like, "How am I going to disconnect my headlight now if I have to?" "Simple," he said. Just unplug the harness INSIDE the headlight assembly and then pull the wires thru.
He recommended I do the same to the other light. That Dodge knows about the problems with the harness. He could have put in a replacement harness but down the road I would likely have the same issue. And maybe not under warranty. This fix was done almost 2 months ago, and since then I have not had a single "bulb-out" issue.
BTW: I had a bent pin in the beginning. The tech originally tried to bend back the pin. Everything seemed to be working. I pick up my truck, drive it for a while and discover I have no DRL on the left side. WTF. That's when the tech decided to cut out the bad part.
Good luck
Once you have Black you'll never go back!
Sport Performance Hood, OEM Mud Flaps, Engine Cover (Hemi Orange), Factory Spray-in Bed Liner, 50 watt - 6000k HID Headlights (low-beam), 35 watt - 4300k HID Fog Lamps, LED License Plate Lights
Old 07-19-2013, 01:51 PM
Well, I checked the ground and it was a little loose. Tightened it up, checked the pins, they all looked good, and havent had another issue. So, I'm hoping the ground was the problem. I guess if it happens again I will have to check the harness itself but, hopefully that got it. Appriciate everyones advise. My truck is just out of warranty so if I can fix it I would rather do that than pay a shop. Thanks again!
Old 07-21-2013, 11:20 AM
Color: green
Rep:657
hope that was the fix and all is well.
Old 07-30-2013, 01:42 PM
The lights are working great "knock on wood". I did have to replace my driver side rear door lock actuator Friday afternoon. Don't know how long it hasn't been working but, my son opened the door when it was locked and the horn started blowing. FYI, apparently it has some type of alarm on it. Then driving through a rain storm in South Louisiana, my daughter noticed my rear window was leaking. Over all I have been very pleased with my truck but, here lately it has been giving me some minor troubles. Such as life. Still a great truck!
