Old 07-05-2013, 02:32 PM
RamLove's Avatar
RamLove RamLove is offline
Vehicle: 1996 Dodge Ram 1500
RamLove is on a distinguished road
Exclamation Radiator Swap HELP!!
So, my radiator has been leaking lately. Not a lot, but enough to leave a small puddle under my truck after I park it. It has become an irritation because I tried to use Stop-Leak and it worked temporarily (about 2 weeks) then began to leak again. I have a question though:
Why are there two radiators? Is one a transmission oil cooler? I thought that was integrated into the main radiator? If I buy a new radiator, do I need a 12" or 14" trans cooler?
Any help or suggestions would be great!
THanks.
Old 07-06-2013, 03:56 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
If you're not the original owner, chances are that someone changed it before you got it.
They may have installed a radiator for a manual transmission and had nowhere to hook the trans lines.
If that's the case I don't understand the question about replacing the trans cooler. If it's not broken it doesn't need to be fixed. Is there a PS cooler and you're mistaking it for a trans cooler?
Old 07-08-2013, 08:08 PM
RamLove's Avatar
There is the main radiator and then a smaller one that looks to be connected to A/C lines.
Old 07-08-2013, 08:31 PM
Jollux Jollux is offline
Vehicle: 1997 Ram 1500 360
Jollux is on a distinguished road
Hmm, If your truck is automatic you have transmission lines that run to the radiator is this what you are talking about? There are separate cores that may make it look like more than one radiator. Can you take a picture, does it look stacked or are they in different areas of the truck?
Old 07-10-2013, 12:18 AM
RamLove's Avatar
Well, it looks to me like the smaller "Radiator" on the front is part of the A/C system. I am buying a new radiator (With trans cooler) tomorrow and swapping them out next weekend.
Old 07-10-2013, 11:36 AM
Vehicle: 95
Rep:1776
After the explanation, I'm going to venture a guess that he's talking about the A/C condenser...
If that's what you're referring to then it's part of the A/C system used to condense the gassious state of the refrigerant back into a liquid form, compressed, returned to the system, wash rinse repeat.
Old 07-10-2013, 04:56 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Yeah, sounds like a condenser. As a side note, those with performance or heavy-duty towing in mind often install an external smaller transmission cooler, usually in front of the radiator. Do not remove the condenser lines from the condenser when doing the radiator swap. If you need to move the condenser, you can loosen the bolts that hold it in place to gain wiggle room.
Old 07-24-2013, 12:05 PM
RamLove's Avatar
I got it all done this past weekend. Really easy job. Had a lot of fun doing it. There is, in fact, a second tranny cooler behind my condenser.
Old 07-25-2013, 10:43 PM
jabba974 jabba974 is offline
Vehicle: 1997 Dodge Ram 2500
Color: Driftwood Satin Metallic
jabba974 is on a distinguished road
My 97 had a secondary trans cooler also...my guess is it was a tow package, or becasue of the 8,800 GVW...some of the aftermarket tranny coolers, such as B&M's are way more efficient then the factory add on...
Old 07-26-2013, 08:43 PM
RamLove's Avatar
It does have a tow package. A really nice one actually.
