Dodge Ram Decals
Old 07-19-2013, 07:43 PM
Windbane's Avatar
Windbane Windbane is offline
Vehicle: 2014 RAM 1500 Sport
Color: Maximum Metallic
Windbane is on a distinguished road
Default Noisy front suspension over small bumps
When going over small sharp bumps, there seems to be some noise coming from the front suspension. Also I can "feel" the road through the gas pedal, if this makes sense. Chrysler replaced the sway links and bushings after I complained of a hollow thunking sound coming from the front (especially loud when in 4x4). I checked the air in the tires and they are at 35psi (still running the crap Wrangler HP's that came with the truck). So I was wondering if anything else in the front end needs replacing (when my Jeep did this they replaced the sway links and the lower control arms). I can't feel anything in the steering wheel, although the wheel is slightly off center when driving straight on the Hwy. There is no pull in either direction, I would think they would have done an alignment after replacing the sway links? Yes-no? Anyway any help would be appreciated, so I can go back to Chrysler and get them to fix whatever is wrong If there is something wrong. Only have 21000kms on it...
2011 Ram 1500 Outdoorsman 4x4
Old 07-19-2013, 10:24 PM
Tongan Built's Avatar
Tongan Built Tongan Built is offline
Vehicle: 2011 Dodge Ram
Color: Stone White
Tongan Built is on a distinguished road
thats weird lol i have the same issue. been that way since ive bought it
Old 07-21-2013, 10:53 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
I have the same issue. My right front sway bar link keeps coming loose. And the lower shock bolt nut keeps getting lose. So I can hear it when it's getting lose again.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 07-25-2013, 12:43 PM
Rocky Harbour Rocky Harbour is offline
Vehicle: 2010 Dodge 1500 Ram - Quad Cab
Trim Level: TRX 4 Off Road
Color: Brilliant Black Crystal Pearl / Light Greystone Pearl
Rep:26
Rocky Harbour is on a distinguished road
Try rotating your wheels front to rear and see if you still have the same feeling in your gas pedal. I noticed that the front tires were prone to cupping and you could feel and hear it at different speeds. I also had both of my front wheel bearings replaced which also made a huge difference.
Old 08-06-2013, 08:37 PM
Windbane's Avatar
I'll try rotating the tires, this vib in the pedal only showed up after I changed from my winter tires to the Wrangler HPs.
Old 08-06-2013, 08:41 PM
Windbane's Avatar
Hmm...but I wouldn't think that it would get loose again after only 3 months, and less than 2000kms? I wonder if aftermarket sway links would be better than mopar?
Old 08-14-2013, 11:10 AM
ramhemi11 ramhemi11 is offline
Vehicle: 2011 ram hemi
Trim Level: slt/sport
Color: mineral grey
ramhemi11 is on a distinguished road
This may sound weird but i had the exact same issue on my 11 with 50,000 kms on it. It turned out to be the power steering rack and pinion gear box that was "worn" was replaced under warranty. It started about 5000kms ago and they couldnt figure it out. When the truck is off shake steering wheel back and forth and it made the clunk you could feel on your feet and the wheel. Hope this helps. It took 2 dealers to solve this but its like a new truck again now.
Old 08-14-2013, 05:13 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:752
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
new rack with that few miles? hope this is a rare occurrence.
Old 08-15-2013, 10:06 PM
bedrock bedrock is offline
Vehicle: 2011 dodge ram
Trim Level: sport
Color: red
bedrock is on a distinguished road
Hey guys mine is the same I can feel the road trough the gas Padel to dodge said its the tires. A week ago driving to work I have to drive over a ruff road to the parking lot and I heard a knockingcoming from the driver side. I have appointment aug 23 made to other dodge dealer to see what they say I hope they find the problem.
