Old 07-21-2013, 05:54 AM
jrioux jrioux is offline
Vehicle: 2005 Dodge Ram
Color: Canyon Red
jrioux is on a distinguished road
Default Towing
I have a 2005 Ram off road package.
It is an automatic transmission.
I have been asked to a trailer for scouts. It is pretty heavy from my understanding; six to seven thousand lbs.
When should I be using the tow haul mode and should I be dropping it down into intro drive?
Thanks for your help.
Old 07-21-2013, 09:17 AM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:221
I think I'd have it in tow haul all the time, maybe lock out OD when in any kind of hills.
Does the trailer have brakes and do you have a brake controller? That's probably the most important part of hauling a trailer that heavy.
Old 07-21-2013, 10:39 AM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
breaking is a big concern. is your truck rated to pull this size trailer? as long as you are set up properly, and within the limits of your truck, you should be ok. if you over spec, things can south, esp when it come s to insurance and being overloaded.
Old 07-21-2013, 10:43 AM
Hermes1 Hermes1 is offline
Vehicle: 2015 Big Horn 3500 Cummins TD
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:2559
As I understand it, selecting tow/haul mode locks out OD.
Best Bruce
2015 Big Horn 3500 Cummings TD Dually w/AISIN Tranny
Old 07-21-2013, 11:42 AM
Color: Canyon Red
I have electric brakes package on the truck as does the trailer. I am registered with DMV as having a GVWR of 10,000 lbs.
Old 07-21-2013, 03:17 PM
stimpy76 stimpy76 is offline
Vehicle: 2007 dodge ram q/c 4x4
Trim Level: big horn
Color: silver
stimpy76 is on a distinguished road
I have a 07 ram q/c 4x4, and I tow a travel trailer that weighs about 6600 lbs with no issues. I have seen some websites that say my truck is rated for 9100 lbs.. good luck and safe travels.......
Old 07-21-2013, 03:41 PM
Arth's Avatar
Arth Arth is online now
Color: Mineral Gray Metallic
Rep:2028
Yep. Just put it in tow/haul and leave it. Don't try to keep up with traffic going through hills like you normally would because you can't!
Keeping it in tow/haul the truck should try to help you stop by engine braking as well.
Just take it easy and remember when you are hauling a good sized load like that slower is faster in some cases.
Chrome... in moderation.
Old 07-21-2013, 09:17 PM
Gecko's Avatar
Gecko Gecko is offline
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
You also have a hemi. The OP has the 4.7...
Supercharged, cammed, other things too!
Old 07-27-2013, 06:38 PM
the6shooter the6shooter is offline
Vehicle: 2013 dodge ram 1500 express st
Color: silver
the6shooter is on a distinguished road
You need to check with your state, and see if you are required to have a weight dist. hitch also. Most states now require it if towing over 5000#.
That way you can steer, at highway speeds. Otherwise your just aiming your truck and trailer down the road.
