Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 09-02-2013, 02:49 PM
CASwanson CASwanson is offline
Vehicle: 2012 Ram Express
CASwanson is on a distinguished road
Question Rear end was overfilled by 1/2 qt like 2011s
So I have 37k miles on my truck and changed the rear, front, and transfer case oils this weekend. When I unscrewed the top drain plug on the rear, about 1/2 qt came out. So it appears they are still overfilling them just like they did for the fix in 2011. I jacked up one side of the rear end and was able to get in another 1/3 qt so I got 2.3 qts back in. Does anyone know if there is a special tool the dealer has to pump in fluid through the breather hose on top of the rear? I'd like to order it for the future if it exists! How are all of you guys getting in the extra amount? Jacking one side like me?
thanks
Craig Swanson
2012 Ram 1500 QC Express, 3.92 w/anti slip, bright silver, 20" polished/painted Bighorn wheels
Old 09-02-2013, 10:10 PM
Hemi N Haw's Avatar
Hemi N Haw Hemi N Haw is offline
Vehicle: 2012 Ram 1500 Laramie Crew cab
Color: Bright White-W7
Rep:139
Hemi N Haw will become famous soon enoughHemi N Haw will become famous soon enough
Smile
Dunno CA. I do know if you go on amsoils website & put in your vehicle info. They'll show a rear diff fill capacity of 4.6 pints or = 2.3 quarts & thats what I was able to put in mine. I used their severe gear. Once my warranties are up I plan on swapping out all the lube covers I can IE trans pan & rear diff cover for the greater capacity fin cooled & drain plug serviceable covers that many after market companies make for these trucks. I know it's silly cause by swapping these items to ones that can hold more fluid that can be cooled w/ external fins as opposed to stock less efficient parts supplied by the automakers. These auto makers rely on any little changes to void a warranty in a hurry. Don't make much sense but it's reality. Good luck pal.
Old 09-02-2013, 10:30 PM
Arth's Avatar
Arth Arth is offline
Vehicle: 2015 GMC Sierra
Color: Bronze Alloy Metallic
Rep:2035
Since I am out of warranty I did swap out the rear diff cover. I am glad I did because when I dropped the stock one almost no fluid came out.
I don't know if they will void any warranties for something like this but I guess it depends on the dealer. I had this cover on when they performed the recall on my truck.
I love it. Has a magnetic dipstick as well as a drain plug so I don't have to take it off or stick some tube down there and attempt to drain fluid.
As stated above I plan to do the transmission pan eventually.
Chrome... in moderation.
Old 09-02-2013, 10:54 PM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Rep:999
That is a beautiful piece of art for a diff cover Arth! That's what I'm saving up for now.
Old 09-02-2013, 10:56 PM
Arth's Avatar
Rep:2035
Don't mean to thread jack but I am getting this to go along with it since I do have a custom exhaust...
http://www.ebay.com/itm/270375695501...84.m1423.l2649
Old 09-02-2013, 11:03 PM
Gantman's Avatar
Rep:999
You're killin me man! Another great upgrade and love seeing the stamp, "Made in the USA". Now to find something to sell to get more money faster! thanks for sharing and sorry for thread jack assisting.
Old 09-03-2013, 12:32 PM
So did you get 2.3 in just by filling to bottom of the fill hole? like I said I know it takes 2.3 which I got in also but had to fill above fill plug in order to do it. I have lifetime max care warranty so I won't be changing rear covers. Looking for people who have personally changed their rear end fluid in 2012 model trucks. thanks
Old 09-03-2013, 12:36 PM
also did fluid come out when you removed the fill plug or did you open bottom plug first when draining?
Old 09-03-2013, 01:49 PM
jp7704jp jp7704jp is offline
Rep:73
jp7704jp will become famous soon enough
Ive found that filling them is difficult as well. Didnt think of jacking up a side though. Nice.
Mopar Cold Air Intake, tonneau, bed liner, front and rear splash guards, custom exhaust, nerf bars
Old 09-03-2013, 02:29 PM
Rep:2906
The way the dealership did it
they filled the level to the fill plug
then put the rest of the fluid in through the vent tube fitting
personally i could not see removing the differential cover to empty the differential if you want to check out the gearing or to fix a Pinion Seal
I wanted a drain plug that was magnetized to hold onto metal filings , a fill plug that was at the correct level, something that had more fluid capacity, & i wanted it to look good & be different, yet not something that would void any warranty
http://www.mag-hytec.com/
