Old 07-22-2013, 04:40 AM
misfit1981's Avatar
misfit1981 misfit1981 is offline
Vehicle: 2012 Ram 1500 Quad Cab 4x4
Color: Silver PS2
Rep:45
misfit1981 is on a distinguished road
Default OEM 20" wheels. Hub or Lug centric?
I only searched for a few minutes but couldn't find out if my stock 20" wheels are hub or lug centric. I'm looking purchasing a set of Dick Cepek DC2 17x9 wheels. They are lug centric and was wondering if they'll work as is, or if I would have to purchase an adapter...
2012 RAM 1500 BH
"To be prepared for war is one of the most effective means of preserving peace." -George Washington
Old 07-22-2013, 07:39 AM
myhemi myhemi is offline
Vehicle: 2012 Ram 1500 HEMI
Color: True Blue
myhemi is on a distinguished road
My guess is hub centric. I just got new wheels for mine and they came with a hub adapter and a warning that they must be used.
Old 07-22-2013, 05:33 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
I know my stock 17's were hub centric. I would guess the 20's are as well.
Most aftermarket rims will come with the adapters required to make them hub centric. My Fuel Hostage ones did at least. I would contact the seller and see if it comes with them.
Old 09-06-2013, 03:21 PM
blackram blackram is offline
Vehicle: 2009 Ram 1500
Rep:12
blackram is on a distinguished road
Hub Centric wheels have a bevel cut into them where the wheel sits against the hub on the truck. Either one is fine. If you do get wheels that are lug centric, the plastic centering ring that comes with them is only used to put the wheel center before you torque them down. You def want the "hub centric" plastic rings to aid in proper centering when installing, but lug centric wheel come with conical shaped lug nuts to help them center anyway. Best bet is to order wheels that come with the correct hub bore, but most companies do not produce them that way. They usually have some massive hub bore that allows them to fit a larger array of vehicles.
09CC4x2 CST 4+1 Front, 20x9 Fuel Nutz 295/60 Grapps, Black Heads+Tails, CAI, Predator, Custom Exhst
