Old 07-22-2013, 05:52 PM
Tom-G Tom-G is offline
Vehicle: 2013 RAM CC 4X4
Color: Blue
Rep:16
Tom-G is on a distinguished road
Default 2013 Ram 1500 Rear Axle Part Numbers and LSD Cross Reference
The question comes up on the forum from time to time on the various rear axle part numbers and whether the Limited Spin Differential is included. As far as I can tell, here is the list of axle part numbers (the complete rear axle including the diff.), production codes, ratios, and diff type.
68142573AC DMC, 3.21 Open
68142574AC DMD 3.55, Open
68142575AC DMD & DSA, 3.55 with LSD
68142576AC DMH, 3.92 Open
68142577AC DMH & DSA, 3.92 with LSD
68142579AC DMF & DSA, 4.10 with LSD
68159839AC DMC & DSA, 3.21 with LSD
I believe this information is correct. If anyone else can add to the list or correct any mistakes, please do.
Hope this is helpful.
Old 07-22-2013, 08:14 PM
rraulston rraulston is offline
Vehicle: 2013 Ram Sport Crew Cab Hemi
Rep:7
rraulston is an unknown quantity at this point
this matches what I have...577AC
Old 07-22-2013, 10:31 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
This information is correct for this axle!!! Added one letter. Info is off my build sheet.
68142575AC DMD & DSAP, 3.55 with LSD
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 12-21-2013, 12:37 PM
MongoSJ MongoSJ is offline
Vehicle: 2014 1500 Crew Cab SB 4x4
Trim Level: Limited, Rambox,3.92
Rep:53
MongoSJ will become famous soon enough
Just took delivery of a 1500 4x4 built last month. The window sticker calls out anti-spin and the build sheet shows DSA anti-spin. When I look at the axle itself I see a different part number than referenced above for LSD. Maybe a revision (AC to AD). Would like to verify if I do have LSD. With the tires off the ground spinning one wheel has the opposing wheel spin the opposite direction. I thought all mechanical type LSDs spun the rear wheels in the same direction. Here is the part number on the axle itself.
P68142577AD 3.92
If it's a revision anyone know what changed?
Old 12-21-2013, 12:49 PM
bouf0010's Avatar
bouf0010 bouf0010 is offline
Vehicle: 2013 Dodge Ram 1500
bouf0010 is on a distinguished road
yeah youre good, AD is just for the new year - it acts like an open diff until the wheel slips.
T-1000 HF 93 Tuned - S&B CAI w/custom air scoop - Moe's 87mm tb - Silver Ceramic JBA Shorties - Magnaflow Y-pipe - GT Custom 22" muffler - V6 E-fan mod - 180 t-stat - Catch Can - bielstein shocks - 2" rear drop coils - Cooper Zeon LTZ 305/55R20
Old 12-21-2013, 01:14 PM
Rep:53
Thanks, bouf0010
Old 03-30-2014, 10:26 AM
RaymondT RaymondT is offline
Vehicle: 2014 Dodge Ram
Color: Fire Red
Rep:12
RaymondT is on a distinguished road
Not a lot of guesswork on my 2014. The tag in the very center bottom of the pumpkin says "3.92 OPN DS" after I scraped a little black paint off.
2014 Ram Sport Fire Red 5.7/8-sp w/3.92
