Old 05-27-2014, 09:04 PM
Kamine Kamine is offline
Trim Level: Bighorn
Kamine is on a distinguished road
Default How To Fit Mud Guards With Wheel To Wheel Steps
As many of you know, mud guard options are limited if you have wheel to wheel side steps. Why Ram could not shorten the steps ever so slightly to allow for both options was frustratingly beyond me, so I took matters into my own hands
Since the steps are made from stainless steel, cutting them is not an issue. If they were steel or chromed aluminum, rust/corrosion and chipped chrome would be a concern but in this case I simply unbolted the steps, popped off the end caps, dropped the steps in the band saw and trimmed 1 1/4" off the ends.
This gave me just enough clearance to fit any brand/type mud guards (I went with Husky because they supply the 3M protection tape).
Before and after, plus the guards installed:
File Type: jpg IMG_20140516_190821_638_zps0b5fe2cc.jpg (50.8 KB, 160 views)
File Type: jpg IMG_20140516_193910_401_zps688c6e27.jpg (51.9 KB, 147 views)
File Type: jpg IMG_20140522_195514_236_zpsb93e0285.jpg (69.5 KB, 164 views)
Old 05-27-2014, 09:45 PM
newtworam1 newtworam1 is offline
Trim Level: Outdoorsman
Color: Cherry
newtworam1 is on a distinguished road
Hmmm...I have the 2014 ram 1500 crew with the wheel to wheel side steps and I just put on the husky mud flaps. Mine fit perfect, didn't have to do a thing..weird
Old 05-27-2014, 09:56 PM
Trim Level: Bighorn
Either you don't have the OEM wheel to wheel steps, or your guards are being pushed forward by the steps. As you can see, I only have 3/8" of an inch between the step and the guard after removing 1 1/4" of material from the steps.
Old 05-27-2014, 10:00 PM
badgerflips's Avatar
badgerflips badgerflips is online now
Trim Level: Express Quad 4x4
Color: Blue Streak
Rep:13
badgerflips is on a distinguished road
My Weathertechs fit with my w2w steps, but I admit it'd look a little better with a bit more of a gap like you have there... My wheels are the 20x9" wide ones and it seems like I get quite a bit of fling-off which ends up all over the truck sides even with the mud flaps. I can definitely see the appeal of having fender flares.
Old 05-28-2014, 10:28 PM
Color: Cherry
Nope, have the ram w2w side steps, but mine do appear to be bigger than the ones in your photo. I did read in the husky manual that sometimes the side step need to be flip from one side to the other in-order for the mud flap to fit better.
Oh well, enjoy having less mud on the side of your truck.
Old 05-29-2014, 08:29 AM
nhra nhra is offline
Vehicle: 2014 Crew Cab Granite Crystal
nhra is on a distinguished road
You can remove the 4 screws holding each perch, and move the running board back a little then redrill and mount them back up.
Old 05-29-2014, 09:27 AM
jlc41's Avatar
jlc41 jlc41 is offline
Vehicle: 2013 Ram 1500 CC
Trim Level: Laramie Crew
Color: Western Brown two tone (Hershey Bar)
Rep:39
jlc41 is on a distinguished road
Kamine, they look good. I too have the w2w oem step and I installed weathertech mud flaps no problem. Go figure.
tint, drop in bed liner, Avs window shades, Raptor bed rails, Dee Zee tail gate damper, Genos cabin air filter, Bak Roll-x cover, Weather tech mud flaps, Recon Xtrem tailgate bar, Moroso catch can, DoMore Slide Step, 5/16 Dual pin stripe, Reese lighted hitch cover, Master lock for hitch receiver, Truxedo bed lites, Hunter SS bull bar, Road Runner embroidered head rests, Plasticolor rear flaps with metal Ram logo, Mopar sill plates.
Old 05-30-2014, 01:17 PM
Bushmaster's Avatar
Bushmaster Bushmaster is offline
Trim Level: Outdoorsman 4x4 CC
Color: Bright White Clearcoat
Rep:83
Bushmaster will become famous soon enough
I got the Huskyliner mudflaps too and aftermarket w2w steps, lot cheaper than OEM and lots of room for the mudflaps.
Bakflip G2 tonneau cover, SunTek clear wrap complete front end, Trail FX wheel to wheel nerf bars, Huskyliner mudflaps, Weather Tech front floor mats, rear Recon mini lightbar,20% tint front door windows, 5% tint rear door/rear window, Smittybilt Lightbar with 10" Rigid LED lightbar
Old 01-23-2015, 06:47 PM
rorr1821 rorr1821 is offline
Vehicle: 2014 Ram crew cab
Trim Level: Lone Star
rorr1821 is on a distinguished road
I have purchased the Husky after comparing to Weathertech. I was sold on the protector tape which is included with the Husky. I have not installed them, but if I have a fit problem I will use your idea. Thanks.
Old 01-23-2015, 09:25 PM
Ballast Ballast is online now
Vehicle: 2014 Ram SXT Quad Cab 4x4
Color: Granite
Ballast is on a distinguished road
Don't know what steps I bought, something cheap aftermarket, 4" oval. They were too far forward, put a rope around the rear support, hooked the ATV up and bent them back a couple inches. All is good now
