need help CODE P0113 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 07-23-2013, 09:35 AM
kellyfj10's Avatar
kellyfj10 kellyfj10 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport 4x4
Color: Stone White
kellyfj10 is on a distinguished road
Default need help CODE P0113
I have a check engine light on for a P0113 intake air temperature sensor 1 circuit high input.
I have replaced the sensor that is between the filter and the throttle body but it did not take care of the issue. Any ideas on what it could be??
Thanks
Old 07-23-2013, 09:47 AM
Asur Asur is offline
Vehicle: .
Rep:4373
The powertrain control module (PCM) monitors the temperature of the air entering the engine. The PCM supplies a 5 volt reference voltage to the Intake Air Temperature (IAT) sensor. The IAT is a thermistor that varies resistance based on temperature. As the temperature increases, resistance decreases. Low temperature results in a high signal voltage. When the PCM sees a signal voltage higher than 5 volts, it sets this P0113 check engine light code.
Potential Symptoms
There will likely be no symptoms other than illumination of the Malfunction Indicator Lamp (MIL - Check Engine Light / Service Engine Soon).
Causes
A code P0113 may mean that one or more of the following has happened:
  • Internally failed IAT sensor
  • Faulty connection at IAT sensor
  • Open in IAT ground circuit or signal circuit
  • Short to voltage in IAT signal circuit or reference circuit
  • IAT harness and/or wiring routed too close to high-voltage wiring (e.g. alternator, spark plug cables, etc.)
  • Faulty PCM (less likely but not impossible)
Possible Solutions
First, if you have access to a scan tool, is there an IAT reading? If the IAT reading is logical then the problem is likely intermittent. If the reading is less than -30 degrees, unplug the connector. Install a jumper wire between the harness connector signal and ground circuits. The IAT temperature reading on the scan tool should be maxed out at the high end. For example it should be 280 degrees Farenheit or higher. If it is, the wiring is okay, and it may have been the connection. If it isn't install the jumper wire between the IAT signal circuit and the chassis ground.
If now the IAT reading on the scan tool is maxed out then check for an open in the IAT ground circuit. If you get no reading at all on the scan tool, it's likely that the sensor signal is open or the 5 volt reference is missing. Check using a DVOM (digital volt ohm meter) for a 5 volt reference. If it's there, then unplug the connector at the PCM and check for continuity on the IAT signal circuit between the PCM connector and the IAT connector.
Other IAT sensor and circuit related DTCs: P0095, P0096, P0097, P0098, P0099, P0109, P0110, P0111, P0112, P0114
