Old 07-19-2013, 12:09 AM
ADA16 ADA16 is offline
Vehicle: 2012 ram 1500
Trim Level: express
Rep:43
ADA16 is on a distinguished road
Default Squeaky noise from bilsteins!!!!
I got bilstein shocks set at 2.1 on about 1 month ago and love them, but all of a sudden they started to squeak when i am driving and i know it is them because when i tried to move the truck (like push it side to side) i heard the noise coming from them. Has anyone had this problem, and/or know how to fix it?
Old 07-19-2013, 12:29 AM
2012ramsportellis's Avatar
2012ramsportellis 2012ramsportellis is offline
Vehicle: 2015 dodge powerwagon
Trim Level: power wagon
Color: blue streak pearl coat
Rep:94
2012ramsportellis will become famous soon enough
Had this issue with my bils about a month after my lift was installed , fix get your self a can of spray lube wd-40 , rustcheck etc.. give the upper and lower spring mounts a spray . I have had to do this again recently , eventually water washes it away .
RCX 6" RCX 1.25" bl Bilsteins at 1.4 Mufflex 18" go-rhino dominator 2 side steps
Old 07-19-2013, 12:34 AM
Trim Level: express
Rep:43
Does this make the squeak go away completely, at least until you have to spray it again?
Old 07-19-2013, 05:47 PM
shears's Avatar
shears shears is offline
Vehicle: 2009 Dodge Ram 1500 Sport
Rep:47
shears is on a distinguished road
A lot of people on this forum run bilsteins and I have not heard/read about this before. Maybe someone else can chime in that runs them?
6" BDS Lift, 35x12.50x18 Nitto Trail Grapplers, 18x9 XD Addicts, FlowMaster Super 10, S&B Cold Air Intake, Solar Gard 20% window tint, WeatherTech DigitalFit floor mats, Debadged, Plasti-Dipped Grill and rear ram head emblem, Tow hooks
Taking Donations for more mods...
Old 07-19-2013, 07:11 PM
Trim Level: express
Rep:43
Ok so i sprayed wd-40 on them and it seems that the squeak has gone away only when i rock the truck, but is still there when i drive over bumps (over 20mph). Could it be something else, or maybe got a bad pair of shocks? Any help will be great.
Old 07-19-2013, 08:39 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
The squeak can come from several places. Most of the time it is the bushings in the shock loop. Other times it is the rubber isolator at the top of the shock. Giving the bushings a quick spray of wd-40 will help. If it continues when you compress the springs then you need to lube the isolator on top of the spring. Remember as the spring compresses it also rotates. The upper isolator should have had some grease applied before install. If it didn't then it can squeak. Its a lot of work to take everything apart, so you may try using the straw to get a good amount of lube up top then drive over some bumps to get it moved around.
Remember anything rubber or poly that moves CAN squeak (doesn't mean it will). Rubber tends to squeak less, but poly last longer. Its a toss up.
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 07-21-2013, 09:35 AM
Rep:94
Me personally , every few 1000's kms I spray every rubber bushing on my truck . keep them lubed up and I haven't and any more squeak's I also spray each spring mounts front and rear .
Old 07-21-2013, 09:54 AM
lowfast lowfast is offline
Vehicle: 2014 Ram 1500 CC 4x4
Trim Level: 1500 Longhorn 4x4
Color: Western Brown Monotone
Rep:92
lowfast will become famous soon enough
FYI, NAPA makes a very thick sprayable grease that works great for these type of issues. I had squeaky bushings on my rear leaf springs, hosed them down with the NAPA grease and after about 5 miles for it to work its way in all noises gone. Because it is thick and sticky it does not wash away with water.
2014 Ram Longhorn CC 4x4 - Born 01/10/14, Western Brown, HEMI, 3.92, LS, AMP PowerSteps, Rancho RS9000 QuickLift and 275/65-20 DynaPro ATMs
2010 Lexus IS-F - Joe-Z Intake
1965 Ford Falcon Hardtop - ProTouring Monster in Progress, 4.6 V8, TCI Suspension, 18x8 & 18x11 Team III Wheels
Old 07-23-2013, 09:45 PM
Trim Level: express
Rep:43
Thanks for the help everyone! The squeaky noise is gone for now!
