tonneaucovered.com
Old 07-23-2013, 10:39 PM
89powerram's Avatar
89powerram 89powerram is offline
Vehicle: 2004 dodge ram 1500 hemi 4x4
Trim Level: Slt
89powerram is on a distinguished road
Default Leveling a 04 4x4
What is the specs to level my 04 4x4 I'm cranking the tbars
-IF YOU CANT DODGE IT RAM IT!!!!
Old 07-24-2013, 08:04 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
What specs are you looking for? Number of turns? I can't remember but it seems like it took 5-6 full turns to get mine up a little over an inch where I thought it looked good. I would start with 3-4 turns measuring from the same point before and after and see what you get. That should give you an idea of how many more turns you need. Be sure to bounce the front end a little or driving a very short distance works even better to let the suspension adjust and reflect the true lift. If you simply crank the bars and measure you will not get an accurate reading. Also, measure so you know what you are doing but level it by eyeball. If you level it my measure and get it dead level front to back it will LOOK nose-high. And lastly, get an alignment after you get it where you want it.
