Mopar CAI (77070023) - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 07-24-2013, 09:50 AM
Warthog Fixer's Avatar
Warthog Fixer Warthog Fixer is offline
Vehicle: 2011 Dodge Ram 1500
Rep:20
Warthog Fixer is on a distinguished road
Default Mopar CAI (77070023)
Does anyone have any experience with the MOPAR Cold Air Intake (P/N 770700233)? I'm walking a fine line between mild performance enhancement and maintaining my extended warranty! If I didn't have the warranty issue I'd go for the Vararam in a heartbeat, along with a host of other items, but I need to be careful... for now.
Old 07-24-2013, 12:16 PM
SOCALSPORT SOCALSPORT is offline
Vehicle: 2013 Ram Sport 5.7 4x4
Color: Deep Cherry
SOCALSPORT is on a distinguished road
I was wondering this as well, I was told by the dealership I had to stay Mopar to keep warranty.
Old 07-24-2013, 12:35 PM
Moderator
Rep:2140
With adding aftermarket parts such as a CAI or exhaust the only way it can void your warranty is if the dealership can prove your mod is what caused the problem. Other than that it should not void it in any way.
Personally I wouldn't even bother with the Mopar CAI. It will give you a little more flow and sound over stock but since it's not a true CAI like the stock set up is you will be pulling in much more hot air. Therefore you are not gaining anything. You would be better off adding a drop in filter to your stock box, changing the intake tube between the box and throttle body, and adding a secondary intake pipe to the bottom of your stock box (search the forum for threads on that).
Old 07-24-2013, 02:20 PM
Rep:20
Lightbulb
SO, a K&N (OEM Replacement) for example and better piping/tubing options over the MOPAR piece? Hey, I'm down for experimenting! I'm trying to search for these old threads right now.
Old 07-24-2013, 02:38 PM
Rep:20
I think I found that thread:
Airbox Intake Tube Mod
Makes sence I guess, I remember guys doing that with thier Camaro's and Firebirds back in the mid 90's.
Old 07-24-2013, 02:45 PM
Moderator
Rep:2140
Yup that's the thread! I even did that mod to my Airaid intake to get more air into it. But if I had to do it over again probably would have done exactly what I told you. For what I gained out of the Airaid intake the cost wasn't really worth it. If they made a Vararam for my truck that would be a different story though....
Old 07-24-2013, 03:03 PM
Rep:20
Or how about the S&B Air Scoop (PN AS-1006)? This looks like the same theory as the dryer hose but finished better, ok and mehbeh a touch more spendy...
Old 07-24-2013, 03:05 PM
Rep:20
...If they made a Vararam for my truck that would be a different story though....
Yeah, after warranty I'm seeing a Vararam and ARH headers in the future!!
Old 07-24-2013, 03:14 PM
Moderator
Rep:2140
If you could get the S&B scoop to work it would definitely be a nicer finish. But since that scoop is made for a S&B intake I can definitely see it being a little difficult to get that hooked up to the stock air box properly.
Old 07-24-2013, 04:31 PM
Rep:20
Unhappy
sob... back to dryer hose >.<
mopar cai 77070023
