Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Old 07-27-2013, 05:52 PM
mikoz mikoz is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Lone star crew cab
Color: stone white
mikoz is on a distinguished road
Default AC drain tube
Hi,
I have a problem that I've read a bit about... at sustained high speeds, the AC doesn't drain very well and can sometimes produce small puddles in the passenger footwell. Otherwise, it appears to be working fine and the puddling (minor) only happens under prolonged 70+ MPH speeds.
The solution seems to be an elbow fastened to the drain tube (which frankly makes sense anyway).
What is the OD of this tube, as I'd like to use a FIP pipe (as opposed to something like a barb fitting which fits internally) to make sure that I'm not disrupting the flow of the water.
Thanks for your help.
