Old 07-24-2013, 11:51 AM
02MOPOWER's Avatar
02MOPOWER 02MOPOWER is offline
Vehicle: 2002 Dodge Ram 1500
Trim Level: St
Color: Bright silver
02MOPOWER is on a distinguished road
Default Wondering on tire size and lifted single cabs
I wanted to make my truck look like this and I was wondering what tire size this is roughly? Btw I have a leveling kit on my 02 1500 and I wanted to do 3in lift spindles and rear lift blocks. Also does anyone have any lifted single cab long beds? Show em off and list your lift and tire size please
Old 07-24-2013, 04:49 PM
DRX350's Avatar
DRX350 DRX350 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
Mine is a short bed, but I have a 2" longer coil/shock (skyjacker spring/rancho shock) in front, and 2" block in the rear. I think I will convert it to the shackle flip kit in the rear for 2.75" lift, because the nose is higher than the back.
Currently I have 31" tires, but soon I am getting 33" BFG all terrains...
Old 07-24-2013, 05:55 PM
02MOPOWER's Avatar
Trim Level: St
I have 31s right now also. I was thinking of getting 33 or 35in general grabber at2. Do you have any idea how big the tires are on that picture? Ive tried to find info on that truck with no luck. All i know is its a cummins 2500 but all id like to know is its tire size. Thanks
Old 07-24-2013, 07:30 PM
dodge.ram dodge.ram is offline
Vehicle: 2006 Dodge Ram
dodge.ram is on a distinguished road
Here is my single cab long bed 2wd lifted 8" on 37's. I did exactly what you described you are looking to do except it also has a 3" body lift. There is also a pic of it before it was lifted.
Old 07-24-2013, 11:48 PM
DRX350's Avatar
Color: Blue-ish
Rep:118
I'd say the tires in the pic are 285/75-16 (35")...
Old 07-25-2013, 12:24 AM
02MOPOWER's Avatar
Trim Level: St
Wow @dodge.ram thats one sick truck. So for me to get the look im going for should i do 33s or 35s? Im not gunna do the body lift because i dont wanna go that high. Also what tires do you have? And how was your mpg affected? And did you change gears? If so to what? I was thinking 3.92s and a limited slip rear out of a hemi if possible for mine. And thank you @dxr350
