Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
MOPAR DECALS
Old 07-24-2013, 04:38 PM
nater nater is offline
Vehicle: 1994 Dodge Ram 1500
Trim Level: not sure
Color: undecided
nater is on a distinguished road
Default 2wd vs 4wd cant decide
I have a 2wd 94 ram 1500 that's torn down to the frame still from repainting it, the engine was junk so i've been searching the web for a dodge engine and came across a 4s4 truck and was just debating with myself what one would be better to build. im mainly looking for something to go from a to b and haul a trailer better from time to time and later on to mods to. what one has more support in the after marker, what are the common problems with the 2wd, how about the 4wd.
p.s. both are long bed truck standard's. ok the four wheel drive right now is auto but that's going to change to a standard before I use it on the road. I need help to decide what one I should build.
Old 07-24-2013, 10:09 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:762
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
living in new hampshire, i would want a 4x4.
Old 07-24-2013, 11:17 PM
RedSmart's Avatar
RedSmart RedSmart is offline
Rep:883
My choice would always be 4WD over 2WD, if nothing more than for the unknown.
Old 07-24-2013, 11:22 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
yep...4 x 4 ............
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter,SuperChip
Old 07-25-2013, 02:30 AM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
definitely go 4x4. much better in winter and if your hauling alot of weight in the trailer it will help when towing as well. and the aftermarket for 4x4's is just as good if not better than for 2wd suspension wise. but both have great options for aftermarket when it comes to engines.....mainly because the 2wd and 4wd have the same motors unless your going diesel.
Old 07-25-2013, 05:03 AM
Color: undecided
so what are some major problems that the 4x4 usually get? ik that dodge is hard on front end parts but is there anything else besides rust that usually goes wrong. now how about with the 2wd truck.
what is a all working automatic transmission worth in your own opion
Old 07-25-2013, 09:40 AM
32seventeen 32seventeen is offline
Vehicle: 2009 Dodge Ram Laramie QC
Color: Brillant Black Pearl/ Sandstone
Rep:25
32seventeen is on a distinguished road
There will always be more things that can go wrong on a 4x4 vs a 2wd.
I have been buying 2wd for the last 20 years, but I don't off road and we don't get very much snow here. Therefore, I don't need a 4wd. I can't say I have ever missed having 4wd either.
If you need or just want 4wd, then go for it.....
Old 07-25-2013, 07:42 PM
Rep:762
guess you don't trek up north in the winter. lol
Old 07-25-2013, 09:52 PM
Rep:68
there a few things to go wrong with a 4x4 but if you keep up the maintenance it's not too bad. i have heard that the 1500's have less front end issues than the 2500 or 3500's. but thats due to different parts and suspension setups. maybe someone more familiar with the 1500 4wd front end can chime in and correct me if my info is incorrect. but i believe the 1500 has a fixed diff and cv axles. it's usually the cv joints that go bad but they usually have a pretty good service life as long as the boots are not torn and they aer well greased. unless your doing some pretty crazy wheeling the transfer case is pretty strong. if it has the electric t-case shift motors they can fail as well. but dodge has a pretty good system in the 1500's. you will have alot less things to go wrong on a 1500 than i do on my power wagon. one more thing to consider as well is if you get the 4x4 it will always have a higher resale value than the 2wd unless your talking the r/t 2wd.
Old 07-25-2013, 10:38 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
I have a 2wd and love it. For the few days a year we get snow I dont need 4wd. I dont offroad it either.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
