A New and Improved Water Leak Issue... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 07-24-2013, 09:31 PM
MrPiper's Avatar
MrPiper MrPiper is offline
Vehicle: 2012 Ram 1500 Bighorn
Trim Level: 1500 Bighorn
Rep:54
MrPiper will become famous soon enough
Default A New and Improved Water Leak Issue...
Last significant rain, my 2012 Bighorn Crew Cab became a swimming pool in the front drivers side floor. The back up camera wouldn't work and the break controller was inoperative.
Dealer paid a subcontractor called "Seal Tech" who sealed the front roof seams, A-post, Drip rail and split seam.
All of the electronics worked fine within 24 hours. I put a fan in the truck and dried it over night. Dealer noted issues in service record but checked nothing as far as I can tell.
Old 07-24-2013, 09:54 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
Wow...I'd be pissed!! I had a bad rear window seal and they added silicone to fix it. The carpet pretty much stayed soaked because it started in spring time in Oklahoma. And took 3 months to get it fixed!!!
Hope your problem is fixed!!!
12 Flame Red RCSB Express- Sold 3/2015
17 Blue Streak R/T Ordered 5/23/2017
Delivered 6/22/17
Old 07-25-2013, 11:34 AM
NSHemi86's Avatar
NSHemi86 NSHemi86 is offline
Vehicle: 2014 Ram 2500 4x4 Laramie
NSHemi86 is on a distinguished road
Does the truck have a sunroof? I put my truck in the shop about a month ago because I had water coming down the driver side A Pillar and water would run down the AC vent and drip on the trailer brake controller causing it to malfunction. They found the front driver side dain tube was kinked and the two back drain weren't even hooked up. Since then no leaks and it has poured rain for the past month.
Old 07-25-2013, 05:27 PM
MrPiper's Avatar
Rep:54
Thanks for the info about the drain tubes. No mention of it. All of the electronics are working fine right now, but I will keep a watch. Hopefully all is well. the dealer was GREAT. I would highly recommend them. Have done business with them for 15 years through 4 different vehicles with never a complaint about their service dept.
