Old 07-25-2013, 10:37 AM
dvarn's Avatar
dvarn dvarn is offline
Vehicle: 2009 Dodge Ram 4x4 QC
Color: Stone White
Rep:187
dvarn has a spectacular aura aboutdvarn has a spectacular aura about
Default lift & tire question
First post for me. I'm considering putting a 6" BDS lift on with 37x13.5 20 toyo mt's on my truck. Will this setup fit without anything additional being added? The wheels I'm looking at are 20x9 xd spy with a -12 offset.
I've owned 3 rams, but this is the first time I've considered doing the whole lift thing. Any info will be greatly appreciated.
Old 07-25-2013, 10:49 AM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
welcome to the board bud...within seconds a forum professional will chime in...some guys on here know their stuff
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter
Old 07-25-2013, 11:05 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
you should be able to fit those 37's with the 6" lift. You might have some minor rubbing on the plastic. but nothing some trimming won't fix. and it won't even be noticeable (the trimming)
Old 07-25-2013, 01:59 PM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
You should be able to run that set up no problem! The only thing I would recommend is going to a 20x10 -24 offset wheel rather than a 20x9 -12 offset. It would look better with that much lift and that wide of a tire IMO.
Old 07-25-2013, 02:33 PM
dvarn's Avatar
Color: Stone White
Rep:187
Thanks for the feedback. When I finally go through with it I'll be sure to post some pics.
Old 07-25-2013, 03:19 PM
dvarn's Avatar
Color: Stone White
Rep:187
Would 37's look too big with this setup? I'm open to 35's also. I just figured the 37's would fill out more
Old 07-25-2013, 04:53 PM
Rep:1900
nope 37s would look great. but if u want to save some $$ 35s still look good.
a lot of tire choices in 37" actually run kinda small like 36" anyway so
Old 07-25-2013, 05:15 PM
Rep:2032
What gears do you have on your truck? 37's will look the best but if you only have 3.55 gears then I'd probably stick with 35's.
I'm running 35x12.5's on a 6" RCX lift with Bilsteins at 1.4" and it just on the edge of being big enough IMO. There's a link in my signature with tons of pictures if you want to see how it looks.
Old 07-25-2013, 07:34 PM
dvarn's Avatar
Color: Stone White
Rep:187
Yeah, I was thinking about the gearing issue with the 37's. My truck does have the 3.55 gears.
Your truck looks perfect, so I'll be looking into 35's as well. Thanks again
Old 07-25-2013, 07:43 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
dvarn, 37's look great with that lift, however as stated above with 3.55 gears it is not really recommended to go that big, I would recommend a 35, and a 20x10 -24mm offset as well as stated above.
If you need pricing on that lift let shoot us an email to sales@bullysperformance.com we will get you the lowest price on the NET and price match anyone selling BDS, we can also get you wheels/tires mounted and balanced w/ TPMS installed and delivered if you are looking for a one stop shop check us out, we ship nation wide and always have the low low prices
thanks
Jeremiah
