Old 07-25-2013, 11:42 AM
Klingfuss Klingfuss is offline
Vehicle: 2014 Ram 1500 Laramie Crew 4wd
Color: Fire Red
Klingfuss is on a distinguished road
Default Leveling the front on a four corner air suspension RAM 1500?
I have a 2013 Ram 1500 without the Air Suspension that I installed a front leveling kit on and it looks and rides sweet. But I just ordered a 2014 loaded up with the air suspension, by the ones I see on the lot with this option it looks like the front does sit lower on those as well and Im going to want to raise it up to level and add my 35 tires off my 13.
My question is does anybody make anything to do that yet? It seems that something mechanical could do it but also programming the front to rise a little bit seems like the smart option if that could happen.
Thanks for any help you may have, or point me to a better place to seek that info out -
Old 07-25-2013, 11:48 AM
Breathing Borla's Avatar
Breathing Borla Breathing Borla is offline
Vehicle: 2013 Ram 1500 Sport 4x4
Color: Maximum Steel
Rep:89
Breathing Borla will become famous soon enough
you are out of luck with 35's on that set-up. If you want to lift, level, or play with the suspension and mod it like that, the air suspension is the wrong way to go.
2013 Ram Sport Crew 4x4, 5.7, 8-speed, 3.92, LSD, Borla
2010 LTD Tundra DC, 4x4 RW Wheels 33" Cooper Maxx
2001 tundra, 2000 tundra
1995.5 Tacoma, 1997 Tacoma, 1998 Tacoma
Old 07-25-2013, 11:57 AM
Tcon Tcon is offline
Vehicle: 2013 Ram 1500 QC 4x4 Sport
Rep:49
Tcon is on a distinguished road
For now..but it will likely come in time.
A tire shop here said guys were installing level kits above the air suspension. I'm not sure I believe him.
5.7L/8 Spd/3.92/Air Ride - Whited Out Badges - S&B CAI, 87MM TB, BT Catch Can, Magnaflow 22", Magnaflow Y Pipe, Weathertech Vent Visors, White 3" Stubby Antenna, DeeZee Tailgate Assist, Bak Flip G2
Old 07-25-2013, 12:02 PM
Rep:89
oh boy, I would NOT want to be the ginnie pig on that set-up.
if you want to lift, stay with the regular set-up. much less to go wrong on a completely new system,
that's just my .02
Old 07-25-2013, 10:34 PM
mids mids is offline
Vehicle: 2013 ram 1500
Rep:73
mids will become famous soon enough
If we could figure out what is used, and how it is used, to determine when to raise/lower each corner, leveling might be as simple/challenging as an adjustment to it.
Black 2013 RAM 1500 Big Horn 4x4 QC with 8spd, Hemi, air suspension, 3.92, 8.4AN, Alpine audio, anti-spin rear. 17" rims, and 3x Infinity Kappa 32.9 in dash location.
Old 07-26-2013, 11:04 AM
evanyj350 evanyj350 is offline
Vehicle: 2012 1500 Crew 4x4
Trim Level: Laramie Longhorn
evanyj350 is on a distinguished road
On aftermarket kits, there is a "level" sensor involved. If there is one on the new Rams, and there most likely is, then maybe you could just adjust the angle of the sensor, and it would trick the truck into raising the front.
2012 Ram 1500 CC Black/Gold Laramie Longhorn - Rambox, 3.92, Lim Slip, Trailer Brakes,
Old 07-26-2013, 12:01 PM
KJ48 KJ48 is offline
Vehicle: 2014 1500 Ram QC
Color: Blue Streak pearl
Rep:122
KJ48 will become famous soon enoughKJ48 will become famous soon enough
I noticed the front upper control arms on this '13 have the little ball for a height sensor rod/arm, if thats the case then you can probably adjust the rod length like the lincoln air suspension and other systems to level it.
Its always possible they have some some kind of tilt sensors as well to keep it level, I have no idea... I would think the air suspension trucks would sit more level, reason for the big rake with normal springs is so it doesnt drag the tail with a load in the bed or trailer attached. I would think the air ride wouldnt need to have any rake since it can level itself depending on load.
Old 07-26-2013, 01:21 PM
Hardrocker06's Avatar
Hardrocker06 Hardrocker06 is offline
Vehicle: 2013 RAM 1500 CC 6'4"
Color: Bright White Two-tone
Rep:12
Hardrocker06 is on a distinguished road
Maybe I haven't paid enough attention to how mine is sitting, but my understanding was that the air suspension was supposed to be self leveling all the time. Hence the reason I hear it leveling after it has been shut off. Maybe the ones you looked at were is some other air susp. mode?
Old 07-29-2013, 10:16 PM
Color: Fire Red
Do you think you could put it in driving mode and measure the front height compared to the rear? the one I seen had at least a two inch differance between the two, looked like a hound dog sniffing a trail
Old 07-29-2013, 11:13 PM
Rep:12
Yeah, I measured to the top of the wheel well and it was 38 in the rear and 36.5 in the front. To the top of the w2w steps, 15 in the rear/ 14 in the front. Probably something that is going to eat away at me now that I know it. Thanks
