2011 strange shifting tranny - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-25-2013, 12:37 PM
skgolfsuper skgolfsuper is offline
Vehicle: 2011 Ram Outdoorsman
Trim Level: Outdoorsman
skgolfsuper is on a distinguished road
Default 2011 strange shifting tranny
Hello all,
I haven't come across this issue anywhere else in our forums so here goes.
When operating in automatic mode, tranny shifts perfectly between all gears.
When operating in push-button manual mode, 1st gear to second works fine, but 2nd and 3rd gear are like exactly the same. 4th and 5th are fine.
To elaborate, an estimate of 600 rpm between shifts gears 1 and 2. 2 and 3 will have an estimated 100 or less rpm difference.
Again, only happens in manual mode; auto shift points seem fine.
I had the tranny 're-learned' by dealership a couple weeks ago but no change.
Any Ideas?
2011 Outdoorsman Hemi/392's/33000 km.
Many thanks!!!
Mark
Old 07-25-2013, 08:12 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
is the tc slipping?
Old 07-25-2013, 09:07 PM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
Originally Posted by skgolfsuper View Post
Hello all,
Any Ideas?
Many thanks!!!
Mark
Yes sir, you are indeed correct in describing your feeling in your trans shifts between 2nd and 3rd. 1st gear ratio is at 3.00:1, 2nd gear is at 1.67:1, 3rd gear is at 1.50:1, 4th gear is at 1.00:1, 5th gear is at .75:1, and 6th gear is at .67:1. It is operating as designed and as you get more manual shift time logged, eventually you will develop the double right tap to go from 2nd to 4th gear when reaching the 5600rpm powerband.
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
