Old 07-28-2013, 11:53 PM
Trim Level: sport
Color: green
Rep:621
no brad. they dc the 5.9 because they couldn't get it to meet the new epa requirements so it wouldn't have all the epa crap that the 6.7 has. 5000 miles a year sounds like it is going to sit a lot, what do the 6.7 ownerss say about that and short trips around town. just for the record, i was driving diesels long before you were tall enough to get in a 3500.
Old 07-29-2013, 12:53 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1945
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
So you essentially proved my point.... If a 5.9 was around it would have all the emissions stuff. Plain and simple. It's not around because it can't meet that...
He said 5000 miles a year which is not a lot but he also said he will be towing and going on trips with it often. Sounds like long trips not short ones to me... So once again, your point is invalid.
My age has absolutely nothing to do with it. Good for you being able to drive a diesel truck. My 8 year old nephew could figure that one out. I guarantee I've done more than twice as much work building and working on diesels and building and working on racecars in my 21 years than you have in your lifetime. So leave useless points like that out of the argument as they prove absolutely nothing.
Sponsored by:
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | S&B Intake w/ Scoop
Old 07-29-2013, 04:51 AM
scrappy scrappy is offline
Vehicle: '12 ram 3500
Trim Level: laramie limited
Color: mineral grey
Rep:29
scrappy is on a distinguished road
Originally Posted by Gantman View Post
Well Bob, as much as I like the Cummins 850ftlbs of torque when properly equipped, you did say you would probably only put around 5000 miles on the diesel a year. With that said, the Hemi is more than enough motor to handle those loads in a 2500 frame. Especially when paired with the 66RFE trans and the 4.10 rear gear. And the only thing you'd have to worry about is a good fuel stabilizer and trickle charger for your Hemi battery when storing.
but will get roughly 1/2 the fuel mileage of the Cummins especially when towing.
Old 07-29-2013, 07:40 AM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
My two cents I have a 2500 Cummins Diesel 4X4 with the 3.73 ratio and I love it you get a little better mileage with the 3.73 than the 4.10's and there is no difference in towing weight. So I would go with that, look at the specs and go with what you feel is right for you what ever decision you make will be the right on as long as it's a Dodge and not one of the (others). Up untill now it's been a good experience besides with the Diesel even God will be impressed with the power you can make with minimum effort.
Old 07-29-2013, 09:14 AM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
When I can hot the diesel up and run it I will. But short hops, no loads as a daily driver, forget it. Get the Hemi and rent a diesel twice a year. R...
