Old 07-25-2013, 08:46 PM
spurge4 spurge4 is offline
Vehicle: 2012 Ram 1500
spurge4 is on a distinguished road
Default gas pedal vibration
On my 1500 I had a slight vibration in my gas pedal and have taken it in a few times to the dealer. The truck has 8500 miles on it and right before I took it in the last time I noticed that the tires were starting to cup. I brought this to their attention and they put it up on the rack and inspected everything. They also completed an alignment and said the castor and toe were slightly out. They then replaced the two front tires( Thank goodness after only 8500 miles). As I was driving it home I noticed once again a slight vibration in the gas pedal. this would only happened with the road being rough or cracked, (if that makes sense). Has anyone else had this issue? Getting very frustrated.
Old 07-25-2013, 08:49 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Could it possibly be the combination of rough roads and your MDS kicking in and out? Just throwin it out there.
Old 07-25-2013, 08:52 PM
It could be I suppose. now the million dollar question, how to stop the vibration.
Old 07-25-2013, 09:18 PM
Hemi N Haw's Avatar
Hemi N Haw Hemi N Haw is offline
Vehicle: 2012 Ram 1500 Laramie Crew cab
Color: Bright White-W7
Rep:139
Hemi N Haw will become famous soon enoughHemi N Haw will become famous soon enough
Wink
I'll bet it's the modular systems they run in these & other modern vehicles. The gas pedal I believe is its own unit that has a harness that plugs into it to function the throttle body via drive by wire. It snaps or bolts to the floor & is most likely a plastic bracket thats not all that rigid. Its like a huge ps3 controller if you will. I sometimes get it & sometimes a slight vibration in the brake pedal after I hit a bump & get a slight jar. But w/ all the corks these trucks seem to have I had forgotten about that one till now.
Old 07-25-2013, 09:33 PM
Gantman's Avatar
Rep:974
I haven't crawled under to see how the pedal assembly is mounted but if it's metal to metal or plastic housing, that would explain road, engine, frame, and or pedal vibration/resonance transferring to your foot. Maybe a well positioned, vibration foam dampener or silicone/rubber washers so as to not affect safety. But I didn't suggest that. Just theoretically speaking.
Old 07-25-2013, 11:21 PM
RAM SPORT CREW's Avatar
RAM SPORT CREW RAM SPORT CREW is offline
Vehicle: 2012 Ram Sport Crew
Rep:110
RAM SPORT CREW will become famous soon enoughRAM SPORT CREW will become famous soon enough
On mine it's the mds. Put it in 6th and it shouldn't do it.
Old 07-27-2013, 09:14 AM
RLM5150 RLM5150 is offline
Vehicle: 2012 1500 CrewCab
Rep:14
RLM5150 is on a distinguished road
+1
I noticed the same thing.
Old 07-27-2013, 12:46 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
subscibed..............
Old 07-27-2013, 01:40 PM
NUG NUG is offline
Vehicle: 2012 Ram 1500ST
NUG is on a distinguished road
Originally Posted by RLM5150 View Post
+1
+ 2. The MDS is worthless. I'd sure like to be able to turn it off ... Permanently!
Old 07-28-2013, 11:36 AM
Rep:110
Either put it in manual mode, tow haul mode, or buy a tuner. 3 options. I use option 1 everywhere except the highway.
