Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 07-26-2013, 12:22 AM
outlawvagabond outlawvagabond is offline
Vehicle: 1988 Dodge Ram 100
Color: Blue
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
outlawvagabond is on a distinguished road
Default rebuilt carb now fast idle and tight accelerator
I just rebuilt my Rochester Quadrajet on my 88 D100.
(With the air filter off) First start up was immediate, but was idling fast. I may have messed something up with reinstalling the accelerator cable/spring. The factory service manual didn't have a detailed diagram on the setup for this. Any ideas?
Thanks
Alright! I adjusted the choke rod and the idle screw. Plopped a new Throttle Return Spring on there and she runs great now!
Thanks for the help fellas. Now I just have to figure out why my radiator is gulping so much antifreeze.
Old 07-26-2013, 04:27 AM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
fast idling when you start a carbed engine is normal. maybe you didn't set the choke right when rebuilt it. if can effect how quick it kicks down into normal idle. i think there is also a screw somewhere that adjusts how high it idles when you have the choke on but i think you usually have to take the carb off to get at it.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 07-26-2013, 01:47 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Yeah, it could just be the choke actually working properly. After running up to operating temp, bump the throttle. Does it settle down? If not, you should start there with adjusting and troubleshooting.
