Mopar sliding toolbox - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 07-26-2013, 05:05 AM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
Default Mopar sliding toolbox
Has anyone used this, or have it ?
It looks like it will fit under a tonneau cover, and would give me a place to store some stuff.
Part # 82211356
Trying to find out if it is worth it, and which bed rails I need to use it.
Good, Bad, Ugly ??
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 07-26-2013, 08:36 AM
Grubrunner's Avatar
Rep:3883
For right around $600.00 and tax OEM.... Nah!
Why does it say it must be used with the OEM Mopar Bed Rails?
Grub out!
Old 07-26-2013, 05:23 PM
TRCM's Avatar
Rep:63
It mounts to the utility bed rails.
This would be perfect for what I need it for, but I'm not sure it will clear my tonneau cover, and around here, if you order it, you're stuck with it.
And by the time you buy the utility rails, it is closer to 900 bucks.
I've seen the box as low as 475, and the rails are 250, so it's not that bad if ya shop around.
Old 07-27-2013, 11:56 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
if that is your only option then go for it. you might want shop around the board and see if you can get better pricing or other options.
Old 07-27-2013, 02:23 PM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1260
You might look at autozone believe it or not. They have one that actually sits ON the bed, and only comes up to the bed rails, doesnt sit over them. I think its $299 before tax. It is designed specifically for use with tonneau covers, and secures to the cargo hooks at the bottom of the bed with 2 custom straps (included).
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 07-27-2013, 02:25 PM
ArmyofOne's Avatar
Rep:1260
Also, there are ones that sit in the bed, along the bedsides. They are plastic composite, and swivel for easy access from the tailgate. they are nifty. I like them better than the rambox because you close your cover and they arent visible. Something about having a visible box on the side of my truck bed makes me nervous, the locks on the rambox dont look beefy enough to stop like a drill or something.
I am buying some of those soon.
Old 07-27-2013, 05:45 PM
Grubrunner's Avatar
Rep:3883
I've yet to find a cargo box that doesn't look workman's type...if you get my drift.
I like them and they have tremendous functionality, but I've yet to find one.
Grub out!
Old 07-27-2013, 06:37 PM
TRCM's Avatar
Rep:63
I have looked at those, but have yet to be able to verify they will hold what I need them to hold (IE, 4 1 gal jugs similar to antifreeze). Also, buying 2 of them isn't much less than this 1 toolbox that I know will hold what I need it to.
I need something that is easily removed and relocated from the tailgate area to the front of the bed when not being used. I store all the tools & supplies for my boat when I travel for tournaments and such, and the box I am using now is almost as big as a regular toolbox, and it is full.
I have also looked at the tonneau mate box, but it's shape makes me think it will have a lot of wasted space in it, and it isn't much cheaper. It also looks like it is not meant to move once installed.
http://www.truxedo.com/tonneau_mate/land.php
This is what I use now........and it is full
http://www.walmart.com/ip/10569596?w...470710&veh=sem
Old 07-27-2013, 10:25 PM
Grubrunner's Avatar
Rep:3883
Is that Rubbermaid secured or just weighted down with the boxe's contents?
Grub out!
Old 07-28-2013, 01:12 AM
TRCM's Avatar
Rep:63
mostly weighted down, but I do have a bar that keeps it from sliding forward.
I keep it at the tailgate because it is so much easier to get things out of it when needed. I just slide it out onto the tailgate, and don't even need to open the tonneau cover. That is why I like the idea of the sliding toolbox. Keep it at the tailgate when in use, and then slide it forward when not needed.
Just not sure how well it will work with my tonneau cover (ie, how tall the box is in relation to the bed sides), and the price is a choker too.
