Old 07-26-2013, 11:09 AM
bparsel bparsel is offline
Vehicle: 2014 Ram
Rep:25
bparsel is on a distinguished road
Default Weird One. Vibe in front associated with Hot brakes. Caliper??
So, the past few nights on my drive home from work Ive encountered this issue. Only on the drive home when Im in more stop and go traffic.
After running stop and go from 0-55 for about 15 miles I have a few miles of zero-60- zero type of expressway driving as well. Once I get off the expressway Ive been getting this issue.
I will apply the brakes which work just fine, then release them and I will get a vibe and noise in the right front. Sounds like when you run your tire off the side of the road into the rumble strips...just not nearly that loud. When I lightly apply the brakes the sound and vibes go away......let off the brakes and it returns. This is all in the 5-20 mph range.
Truck has new pads, rotors, tie rods, struts, sway bar bushings, upper ball joints and upper control arms about 2k miles ago and the problem just started.
I'm thinking partially seized caliper when it gets hot??? Caliper heats up and only 1 piston is releasing fully...hence when I lightly apply the brakes it evens out the pads and makes the vibes and noise go away???? I wouldnt think a cock-eyed pad would cause that much vibe though.
No unusual wear pattern on the pads......any ideas or thoughts on this one?
Old 07-26-2013, 11:22 AM
Adamthc Adamthc is offline
Vehicle: 2013 ram 1500 Outdoorsman
Trim Level: Outdoorsman
Adamthc is on a distinguished road
sounds like warped rotor to me but you say you changed them eh..
Old 07-26-2013, 11:29 AM
Vehicle: 2014 Ram
Rep:25
Correct, rotor is only about 6 wks old. I would suspect rotor as well if it did it all the time, but it's only when the brakes are really hot. And applying the brakes lightly makes it go away.
I should also note that I hit both sides of the brakes last night with my laser temp gauge when i pulled in the driveway.....nothing unusually hot in comparison to other components.
Old 07-26-2013, 03:00 PM
deanhinsley1963's Avatar
deanhinsley1963 deanhinsley1963 is offline
Vehicle: 2004 Dodge Ram 1500
Color: silver
Rep:12
deanhinsley1963 is on a distinguished road
I was thinking wheel bearing assembly myself. To check this take the caliper off and see how it turns or if it has slack. The caliper will hold the hub steady when brakes are applied then let the slack back in it when released.
Old 07-26-2013, 04:03 PM
Vehicle: 2014 Ram
Rep:25
I suppose its possible. Ive never had a bad wheel bearing act like this before or with these type of symptoms though. I always get the constant growl/ vibe that changes with turning.
I'm going to tear apart the whole right front this wknd. I WILL figure it out.
Old 07-26-2013, 07:22 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
I think you right and are having a problem with the piston returning. Have you ever had a brake fluid flush? or at least bled out the nasty stuff in the calipers? (fluid closest the caliper sometimes cooks and breaks down much faster than the rest of the fluid) I say do the procedure like you are bleeding the brakes of air and drain it into a clear bottle. if it's really dirty and full of sediment it may need to be rebuilt or replaced.
Tip: find a clear hose that fits onto the bleeder fitting and run it into your catch bottle.
Old 07-31-2013, 02:28 PM
Vehicle: 2014 Ram
Rep:25
Default Solved
One of my biggest pet peeves about this forum is that hardly anyone ever goes back and finishes their threads with solutions etc. Drives me nuts!!
Anyways, found the culprit. It was my passenger side caliper seizing when it got over heated.
I pulled the caliper off and proceeded to pump the brakes. Only one piston came out - nothing unusual without an even load on them. I pushed the piston back in and blocked that piston with a socket wrench and went and pumped the brakes again. 2nd piston came up -again, nothing unusual. BUT, when I went to push the piston back into the caliper it wouldnt budge. I cranked on the clamp and never got it to move. That was enough to justify my hypothesis. Yanked the caliper off.....purchased new one....installed.....bled brakes.......and NO issues/ sounds/ vibrations now since Saturday morning.
Old 07-31-2013, 03:02 PM
HemiLonestar's Avatar
Rep:289
Had this same problem, ended up rebuilding the caliper (my calipers are a bit more expensive than yours to purchase outright...)
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red" (Mods list in profile)
2006 Charger R/T "Little Red"
Old 07-31-2013, 03:19 PM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Nice find, Dood! Reps for the find and the resolution post.
Old 08-02-2013, 05:23 AM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
rep deserved. now i know what to do if i come across this problem. thanks for the follow up.
