Old 07-27-2013, 03:24 PM
toober's Avatar
toober toober is offline
Trim Level: Tradesman
Rep:26
toober is on a distinguished road
Default Removing Floor Console?
What is the easiest way to remove the floor console? The only use I could see somebody using it for is to hold pens. It is too shallow to hold anything else and is completely in the way for feet if someone sits in the middle seat. Can it be removed? Why is it there??
Old 07-27-2013, 04:09 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Yes you can remove it, remove the tray, it press fits over the plastic unit, in each corner theres is a screw, remove both screws, lift the front part and pull towards the dash, it will un-clip from the seat.
Old 07-30-2013, 05:43 AM
aepowell's Avatar
aepowell aepowell is offline
Vehicle: 2013 Dodge Ram SLT LONESTAR
Trim Level: 1500 SLT LONESTAR QC
Rep:99
aepowell will become famous soon enough
My bench seat didn't come with it.
Aepowell Sherman,TX.
Old 07-30-2013, 11:13 PM
toober's Avatar
Rep:26
I didn't quite understand what you meant here by remove the tray, Yes, that is the ultimate goal. After 2-3 minutes of feeling around for screws near the seat and getting frustrated, I accidentally popped up the rubber 'tray' you mentioned. I had no idea the entire thing wasn't plastic! But yes, once the rubber filler tray is pulled up, the two socket screws are visible, 4 inches down, uhm, what? It really needs them 4 inches down? Any ideas on what I can use to cover up the holes once it is removed? I don't want junk falling into them.
Old 07-30-2013, 11:14 PM
toober's Avatar
Rep:26
This is for a 2013 with 3 front seats (middle seat-back console fold down).
Old 07-31-2013, 01:22 AM
aepowell's Avatar
Rep:99
I know. That what is called the bench seat. Thats what mine has, but no tray on the front of the middle jump seat.
Old 09-16-2013, 05:30 AM
Landman Landman is offline
Vehicle: 2015 Dodge Ram Quad Cab
Landman is on a distinguished road
Mine doesn't have that either. Could you post a picture of the console? Thanks.
Edit: Sorry, I just realized yours is a 2013. Disregard my post. Thanks.
