Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
ZDOG
Old 07-27-2013, 10:19 PM
89powerram's Avatar
89powerram 89powerram is offline
Vehicle: 2004 dodge ram 1500 hemi 4x4
Trim Level: Slt
89powerram is on a distinguished road
Default Changed spark plugs and still poor mileage
I changed the plugs on my hemi and I'm still gettin 12.3 on the interstate and it won't stay at 70mph I. 5th gear it stays in 4 th to keep at 70
-IF YOU CANT DODGE IT RAM IT!!!!
Old 07-28-2013, 02:48 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
It stays in 4th to keep the rpm up? Or it stays in fourth because it's stuck in stupid (limp in mode)? Sounds more like a tranny issue than an engine issue. Could be getting poor mileage because with it staying in fourth, it's not going in to OD allowing the RPMs to come down. Higher RPMs need more gas which equals poorer mileage.
Old 07-28-2013, 09:20 AM
89powerram's Avatar
Trim Level: Slt
It will go into OD but it bogs out and goes back to 4th
Old 07-28-2013, 09:46 AM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:235
I'd take it to Autozone and have them plug it in and check for codes. It sounds like the engine is down on power and not able to pull 5th gear. There are so many things it could be its tough to say. Have you checked the air filter, fuel filter and other maintance items like that.
Old 07-28-2013, 10:20 AM
89powerram's Avatar
Trim Level: Slt
It has no codes and all filters are changed except fuel cause I can't find it and I changed plugs new air sensor and I ordered a new Pcv valve btw the truck has 100k
Old 07-28-2013, 12:34 PM
Rep:2968
Your fuel filter is on your fuel pump inside the tank.
Old 07-28-2013, 09:47 PM
89powerram's Avatar
Trim Level: Slt
That sucks does it need to be changed or what
Old 07-28-2013, 10:31 PM
Rep:2968
I know it's a PITA, but that's where I would start.
Old 07-29-2013, 06:46 AM
89powerram's Avatar
Trim Level: Slt
I don't think fuel delivery is the problem it uses PLENTY of it I think it's the Pcv valve idk yet
Old 07-29-2013, 11:00 AM
Rep:2968
Yes, there are a ton of different things it could be. Change your PCV valve and your EGR. They are both relatively inexpensive. Again, check for vacuum leaks and see how it does.
