Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 07-28-2013, 01:45 AM
larry58v larry58v is offline
Vehicle: 1996 D3500
Trim Level: SE
larry58v is on a distinguished road
Red face Fuel pressure relief
I have had my 96 3500 duel wheel parked most of the winter and spring. I discovered an issue with fuel pressure when I took the rig out of the yard and began getting it ready for a trip. I've started throwing fuel from the tank if the cap is locked down. I just took a trip from Nampa to Moscow and while I got 13.2 going up and about 13.6 coming back, I have to leave the fuel cap loose or the rig pumps up pressure in the tank and causes fuel to expel from the top of the tank someplace. I worry about this only because running with a loose cap should cause a fault code to throw and yet I am not getting either a hard code or a soft temp code on either the dash or my code reader. I have had back surgery last year and I don't move very well on my back crawling under even something as tall as this 4x2. Any suggestions will be appreciated.
Old 08-04-2013, 03:15 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Do you have any issues when you fill the truck up?
Old 03-01-2014, 08:17 PM
sasquatch661 sasquatch661 is offline
Vehicle: 1999 Dodge Ram 2500 Quad Cab
sasquatch661 is on a distinguished road
I had a similar problem of fuel leaking from the top of the tank. I didn't feel like taking the bed off, nor dropping the tank, so I found an alternate solution. I found I was able to squeeze between the frame and the bed (in front of the driver's rear wheel). I used a bit of 3/8" fuel line, a bolt, and two hose clamps to fix my issue. Here is a pic of my fix:
http://i.imgur.com/n8Sx6.jpg
Old 03-06-2014, 10:54 PM
Cheatham Cheatham is offline
Vehicle: 2012
Color: Grey
Rep:17
Cheatham is on a distinguished road
diesel 2nd gen do the same thing if filled up to the max. its just a breather, as fuel heats up from temps it expands and shrinks when cooled so the tank needs to breathe or it will expand alot or rupture, just add some hose and better yet add a filter or fuel filter to keep it clean and find a place to tuck it away above the tank
