Old 07-30-2013, 07:11 PM
andrew93's Avatar
andrew93 andrew93 is offline
Vehicle: 2002 ram
andrew93 is on a distinguished road
The heads were redone by a good machine shop and he replaced the valves I also noticed that a few of exhaust valve don't seat all the way when the cam and rocker arms are installed and I have a filling the noise I'm hearing is a rod bearing
Old 07-30-2013, 08:33 PM
LEW LEW is offline
Vehicle: 2002 Ram 1500 Quadcab 4X4
LEW is on a distinguished road
Your response was: The heads were redone by a good machine shop and he replaced the valves I also noticed that a few of exhaust valve don't seat all the way when the cam and rocker arms are installed and I have a filling the noise I'm hearing is a rod bearing
If a valve doesn't seat all the way on the compression stroke, you WILL have a compression problem!
If the noise you hear sounds like it's down toward the bottom of the engine, you may be right. If it's up toward the top, may be a lifter. It is difficult to tell sometimes. You can use a mechanics stethoscope (maybe a loaner from some car parts stores) that may help.
Good luck.
Old 07-31-2013, 09:46 PM
andrew93's Avatar
Vehicle: 2002 ram
Ok i have the motor completely apart and all the valves are seating properly the 2 or 3 of the rod bearings make noise when i move them side to side not a lot of play just a little in them so going to replace all the bearings. But my question is its there any way to check if the piston rings are bad or not cuase really dont want to remove them if i dont have to.
Old 07-31-2013, 10:55 PM
deanhinsley1963's Avatar
deanhinsley1963 deanhinsley1963 is offline
Vehicle: 2004 Dodge Ram 1500
Color: silver
Rep:12
deanhinsley1963 is on a distinguished road
If I was into it that deep I would do the whole rebuild thing.
Old 07-31-2013, 11:39 PM
RogerRamJet's Avatar
RogerRamJet RogerRamJet is online now
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Agreed. ^^^^^^ Since you're already there, do it right so you don't have to do it again.
Old 08-01-2013, 12:29 AM
andrew93's Avatar
Vehicle: 2002 ram
ok was looking at the cylinder walls again and #1 has scratches on the wall up and down so guess thats were im losing the compression and i am going to do a complete rebuild
Old 08-01-2013, 12:38 AM
andrew93's Avatar
Vehicle: 2002 ram
Here's a picture of the number 1 cylinder wall let me know what y'all think going to take it to the machine shop tomorrow and see what he says also if I run my finder nail over the scratches I can fill the scratches but my nail doesn't not hang up or anything the scratches are light
