Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 08-13-2013, 07:12 PM
10strokin 10strokin is offline
Vehicle: 1993 D250
Color: grey
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
10strokin is on a distinguished road
Default torqueflite swap
Hi all, 93 Dodge D250. Was the old A727 or 904 torqueflite 3 speed auto still offered in these trucks as an option, or is it even possible with the computer controlled 5.2/5.9 engines?
Old 08-14-2013, 10:49 PM
Vehicle: 1993 D250
Color: grey
Ford offered the old C6 3 speed tranny right through 97 as an option. Just wondering if it was optional here, thats all...
Old 08-14-2013, 11:48 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Don't know for sure, but I did see a '95 Ram van with a Magnum V6 and the A998. I'd never heard of such a thing, but the tags and labels were all there. It was a factory job. So I guess it's possible. The 904 had pretty much been superceeded by the 998 and 999 variants. I would think in a 250 it'd be the 727. Computer control isn't an issue on these older 3 speeds. One old trick in swaps was to just use a computer for a manual transmission just to avoid a check engine light.
Old 08-17-2013, 11:35 AM
Vehicle: 1993 D250
Color: grey
Are there any articles to search on this site for tranny swaps from 4 speed back to A727??
Old 08-17-2013, 03:13 PM
Rep:85
I know Chrysler used the 727 behind their 5.9 Cummins diesel until a beefed 518 came available. Anyway, don't know of any articles, but it's pretty simple. If you're going to use the fuel injection, you will need to notch the bellhousing as is on the 518 for the crank sensor to see the flexplate exciter. You will need to use the Magnum flexplate for the fuel injection. The 727 bolts right in place, including the starter, fluid lines, and kickdown mechanism, which must be hooked up or you will burn the transmission up quickly. You will need a driveshaft about 4 inches longer. Also, due to the length, the transmission crossmount is different, requiring an older matching crossmember, or removal of the extension. It depends on the vehicle. I've seen newer units that are re-dimensioned for the different transmission, and I've seen the same decades-old crossmember with an extension bolted to it to accommodate the change. The 5.2 is internally balanced, but the factory 5.9 is not and requires external weight. Traditionally, Mopar put that weight on the torque converter. The 5.9 Magnum uses less weight than the pre-Magnum "LA" 5.9/360 so keep that in mind. The "front three" gears on the 518 (essentially the 727) are controlled hydraulically, so as long as the kickdown linkage is in place, it'll run fine. Use the speedo unit from the OD transmission on the 727. If you don't mind a check engine code from the computer not finding an OD, you're good to go. Only issues are if you use a lockup 727 or the much more common non-lockup unit. If a 5.9 Magnum, use the torque converter for the A518 '89-92 for a non-lockup 727. If a lockup and a 5.9 Magnum, you will need a lockup converter for the 727 (mechanical lockup, not electric like the OD units), balanced for the Magnum. A little more tedious, but not a big deal. SMR and other shops sell balance plates that can be bolted in to achieve proper balance. No balance weights needed for the 318/5.2 LA/Magnum.
Old 08-17-2013, 10:30 PM
Vehicle: 1993 D250
Color: grey
Wow! Excellent information, thank you.
