Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
tonneaucovered.com
Old 07-28-2013, 01:20 PM
dsurmanek dsurmanek is offline
Vehicle: 2008 Dodge Ram 1500 Quad Cab
dsurmanek is on a distinguished road
Default Need map light clip fix
I was swapping my factory map light bulbs for LEDs. When i was taking the map light off the little pin that the lens clips on to broke off on one side of each map light. Both lenses hang down on one side now. Any tips?
'08 Ram 1500 QC 5.7 Hemi 2wd
Old 07-28-2013, 01:45 PM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
got pics of it? might help to see what broke to come up with an idea of how to help you.
Old 07-30-2013, 09:29 AM
the lenses are just fine though
Old 07-30-2013, 06:23 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
Do you still have the pieces that broke off? might be able to get away with using an epoxy like jb weld to "glue" the pieces back on.
Old 07-30-2013, 10:54 PM
Nope. They probably went flying somewhere when they snapped. Plus, would any kind of glue hold up to the pressure of popping the lenses back on?
Old 07-30-2013, 11:33 PM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
You're going to have to replace that whole console piece. I'm in the process of doing it myself right now, thanks to my 2yo nephew. I have seen them on ebay for around $70. [This] will be a good start, shop around though and see what you can find. Check your local salvage yards as well.
Old 07-31-2013, 11:42 AM
Color: Mineral grey
Rep:109
As I said. Jb weld. it's a two part epoxy. you mix them in equal parts and when it cures its stout enough to sand, paint even drill and thread. maybe find something the same diameter of the broken piece and epoxy it in place.
Old 07-31-2013, 11:56 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
IF you can locate the broken tab. Vacuum with a piece of pantyhose stretched across the tube connection might help.
Coffee straws and metal tape.
Tape off the light/lens so you don't get any drips on it.
Get a couple plastic coffee stirrers (straw kind) and light the end on fire. Let it drip onto the broken lens and then set the broken tab in place and hold it for about 10/15 seconds.
Practice with the straw first so you get the feel of it. It'll explain the metal tape.
Old 08-01-2013, 12:47 AM
the lenses are just fine. the plastic bent a little during removal but i bent those back. the only broken part is just the tab that the lens clips on to. also - i doubt i'll be able to find the broken pieces. I work construction so sadly the inside of my truck is usually kind of messy
Old 08-01-2013, 01:17 AM
RedSmart's Avatar
RedSmart RedSmart is offline
Rep:883
I would tape it into place as a temporary measure, and then do as RogerRamJet suggested.......hello Ebay.
Good luck.
