PRO's & CON's of Wheel spacers - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 07-28-2013, 04:08 PM
HULK's Avatar
HULK HULK is offline
Vehicle: 2007 Dodge 4X4 (HULK SMASH)
Trim Level: SLT Lone Star 4x4
Color: Gun Metal Grey
HULK is on a distinguished road
Exclamation PRO's & CON's of Wheel spacers
MY local 4 wheel shop told me that they don't recommend using wheel spacers. Also they wouldn't put them on for me if I wanted them too anyways.
So whats the problem with Wheel spacers? If I am doing some serious mudding or mild rock crawling are there any disadvantages of having them?
WHats the wear and tear on them?
I have the Adjustable Bilistien level shocks on my truck looks and feels great. Just running a smaller tire right now. I want to run a 35 with my stock 20" but not sure about wheel spacers. OR if I even need them. But also thinking about running a 17" wheel just to get a little more Rubber.
Any inputs on the Wheel spacers or my idea of running a smaller wheel?
2.8 level, Train horn, bed cover, headlight brows, blackout grill fins, side steps, reverse work lights, Cameo neoprene seat covers, catchalls, onboard air system.
Old 07-28-2013, 05:54 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
1) depending on the style of spacer, they could require longer wheel studs
2) they change the location of the weight outside the balljoints (move the tire farther away) which increases wear on the suspension & steering systems from the added leverage
3) they can lead to scrubbing of the front tire while turning because the tire is farther away for the actual pivot point of the steering system
4) can allow the wheel to become off center in relation to the hub
Just a few things to consider.......
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 07-28-2013, 05:57 PM
Grubrunner's Avatar
Rep:3883
What was your local shop's input on why they wouldn't recommend them?
Grub out!
Old 07-28-2013, 07:18 PM
browndawg's Avatar
browndawg browndawg is offline
Vehicle: 2012 ram 1500 4x4 express rcsb
Color: true blue pearl
Rep:101
browndawg will become famous soon enoughbrowndawg will become famous soon enough
hey grub is that kurt Russell off the movie backdraft in your sig lol
Old 07-28-2013, 07:24 PM
Grubrunner's Avatar
Rep:3883
No, I don't believe so.
I'm a member of a firefighter's forum and I just borrowed another member's gif.
Grub out!
Old 07-28-2013, 09:54 PM
browndawg's Avatar
Rep:101
have you ever seen that movie, I swear its a scene out of it anyways great movie, sorry to op for slightly highjacking the thread, carry on.
Old 07-28-2013, 10:36 PM
Grubrunner's Avatar
Rep:3883
Yes I've seen it.
Too many times.
Still enjoy it.
Grub out!
Old 07-29-2013, 02:48 AM
HULK's Avatar
Local shop says that "its not safe up to their standards" Also it creates bad wear and tear on the suspension and then they cant warranty the lift parts. But the main thing he said was the safety. Because he has had customers do it after the fact of his work, and they have come in with wheels falling off and cracked steering arms and stuff...
I dont want to do it if I dont have to.
Old 07-29-2013, 03:23 AM
HULK's Avatar
hey TRCM- Would I need a wheel spacer for the front wheels if I run a 35 on the stock wheel?
Old 07-29-2013, 04:10 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
yes most likely. the issue is the width of a 35"
tire. not the height. if you get a tire like my federals, they run like 11" not 12.5" so u wouldn't need a spacer probably. now nitto trail graps that run OVER 12.5" you would def need a spacer.
I'd save up and get a set of offset wheels. they look better and allow you to run wider tires without a spacer. but if u have to run ur stock wheels. have the shop install them and deal with rubbing until u get home and put the spacers on yourself
