Old 07-29-2013, 04:58 AM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
Originally Posted by HULK View Post
hey TRCM- Would I need a wheel spacer for the front wheels if I run a 35 on the stock wheel?
No idea...only vehicle I have run spacers on is my jeep cherokee......
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 07-29-2013, 02:46 PM
HULK's Avatar
HULK HULK is offline
Vehicle: 2007 Dodge 4X4 (HULK SMASH)
Trim Level: SLT Lone Star 4x4
Color: Gun Metal Grey
HULK is on a distinguished road
THanks I will have to save up for some new wheels and tires.
hmmm now what color black or chrome.........
2.8 level, Train horn, bed cover, headlight brows, blackout grill fins, side steps, reverse work lights, Cameo neoprene seat covers, catchalls, onboard air system.
Old 07-29-2013, 03:14 PM
Untamed's Avatar
Untamed Untamed is offline
Color: Grey
Untamed is on a distinguished road
Spacer ?? adapters??
Do you consider those in the same category?
I've ran adapters on my Sonoma that I wheel pretty hard. no problems. Adapters on the back of my 300whp mustang with sticky tires. no problems. And adapters on my Ram. No problems.
You just have to make sure to sink the studs in the adapters when tightening them on.
- 3.75" RC Combo Lift - 20" Zinik Wheels - Mud Grapplers - EGR Rugged Flares - Magnaflow 14" -
- IAFF Local F-160 -
Old 07-29-2013, 03:42 PM
TRCM's Avatar
Rep:63
Well, yes I do. The only difference is an adapter changes the bolt pattern as well as spacing the tire out.
Old 07-29-2013, 05:14 PM
Grubrunner's Avatar
Rep:3883
Grub out!
Old 08-02-2013, 10:37 AM
4.7Ram's Avatar
4.7Ram 4.7Ram is offline
Vehicle: 2007 Dodge Ram 4.7
Trim Level: SLT LoneStar
Color: Electric Blue Pearl
4.7Ram is on a distinguished road
the adapter doesnt have to change the bolt pattern, i have 2 inch wheel spacers (adapters) on my ram and there perfectly fine, no problems whats so ever. you just have to make sure you get the spacer with the studs on them. they do slightly speed up the were of the joints and what not but so will an offset rim, i would personaly never seriouse rock crawl with em but for daily driving and some simple mudding i dont see why not.
Old 08-02-2013, 12:03 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
As mentioned already, there is nothing wrong with running spacers.
As far as added wear it is no different than running a low offset wheel.
Make sure you buy hub centric spacers and if more than 1/4" thick add longer wheel studs or buy spacers with pressed in studs. There is nothing wrong with running a quality spacer made out of high grade material. Dually's come with spacers from the factory.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Carli
Old 08-02-2013, 04:22 PM
TRCM's Avatar
Rep:63
If the 'adapter' doesn't change the bolt pattern, then what is it adapting ?>> nothing.
It is just spacing it out, hence the term 'spacer'.
Old 09-05-2013, 06:31 PM
blackram blackram is offline
Vehicle: 2009 Ram 1500
Rep:12
blackram is on a distinguished road
An adapter IS a spacer. You cant adapt bolt patterns without space to do so! People call them both spacers/adapters. Depends on what website you look at. They refer to the adapters as 5x5.5 to 5x5.5. They do still term them adapters, although they ONLY serve as spacers! Its a little confusing, but even tho they don't actually ADAPT, some companies still refer to them as adapters. Make sure to get the Hub Centric Spacers/Adapters for whatever you want to do with them (either adapt to another pattern or space you wheels out). They are more expensive, but a MUCH better product that can negate the effect of wobble and shake on the drivetrain. Locktite and re-torque after 500 miles is the standard!
I am referring to the ones that have the pressed in studs in them. I need to get some for the rear of my 2wd cause of the pushed out front tires with the CST Lift Spindles. Trying to figure out what the minimum thickness would need to be in order to NOT have to cut the factory studs!
09CC4x2 CST 4+1 Front, 20x9 Fuel Nutz 295/60 Grapps, Black Heads+Tails, CAI, Predator, Custom Exhst
