Found my truck - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
Diesel Forums!
Dodge Caliber
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 07-28-2013, 05:49 PM
1930 1930 is offline
Vehicle: 1929 Dodge
Trim Level: basic
Color: blue
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
1930 is on a distinguished road
Default Found my truck
I was not even sure this model existed but I am now the proud owner of my ideal truck. its a 1986 4 wheel drive with a slant six engine and a 4 speed manual trans, exactly what I wanted.
I was told that the drivetrain was all original and it looks like it I guess, I was told that it has a dana 44 front and rear, does that sound correct for the model truck? Maybe there is a tag that I can take a picture of for someone here and I can get it decoded.
How can I recognize these diffs as Dana 44s?
I am also wondering what model trans is in it, as mentioned 4 speed with granny low, it also has the cover for a PTO if one were inclined.
Supposedly has a new clutch, previous owner at least looks like he jerryrigged alot of things, it chatters REAL bad when taking off in low or first gear, alot of pedal, maybe its out of adjustment, not such a problem taking off in second or at least not nearly as noticeable or more manageable if it is there. Any ideas what might be the deal with that.
The truck is as far as I can tell ( I am a bodyman with enough experience to tell whats what ) there is no major rust except above the windshield, the drip rail is completely rotted away, makes no sense cause the floorboards, inner/outer rockers, bottoms of doors ect are so clean you can literally eat off of them.
I am not going to mess with the drip rail, I went and looked at an 84 yesterday afternoon that sat outside for many years on a concrete pad and there is Zero rust on this sheetmetal, I plan to buy this and swap out the cabs, it all has to be disassembled anyway for paint, the doors on this donor cab open and shut as if it were still sitting on the showroom floor.
Can someone please confirm for me that an 82 cab/doors/glass ect are the same as this 86?
More later, thanks for the help.
Old 07-28-2013, 08:51 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
dana 44 front, but the rear is likely an 8 1/4 (not 9 1/4 and not dana 44)
Never seen a dana 44 rear axle in a full size dodge truck, and they used 9 1/4 or dana 60 behind the v-8's back then.
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 07-28-2013, 09:30 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:782
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i had an 86 ford with the 4 speed manual, 1st gear was a granny gear also. attached to the streight 6.
Old 07-30-2013, 11:00 AM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
It was optional for a few years. Havent seen many of them, but they were out there. Another common one was to pull them of the FSJ trucks as they were damn near a bolt in.
Just Got it, Give me time!
Old 07-31-2013, 05:57 AM
Vehicle: 1929 Dodge
Trim Level: basic
Color: blue
How would I tell what sort of axles are in the truck, also need to know the type of trans. I am not having much luck locating rubber for the truck, I need all new seals all over, door seals ect.
Old 07-31-2013, 08:16 AM
Color: Granite
Rep:286
Have you tried companies like LMC, Brothers Truck Parts, Classic Industries, etc. ?
Old 07-31-2013, 08:39 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Originally Posted by 1930 View Post
Supposedly has a new clutch, previous owner at least looks like he jerryrigged alot of things.
Hey! It's called jury rigged, not jerryrigged. If it was Jerry rigged it would have been done right the first time and you wouldn't have to repair anything. I always fix everything right the first time, always have always will, lol. All said, have fun with your new toy and good luck with the parts....Jason
Old 07-31-2013, 07:21 PM
TRCM's Avatar
Rep:63
Take a pic of the cover, and compare it to pics online, there are numerous places to see what axles are what and determine what you have.
