Old 07-28-2013, 06:38 PM
KingNothing KingNothing is offline
Vehicle: 1999
Trim Level: SLT Larmie
KingNothing is on a distinguished road
Default 99 RAM2500 let me test your knowledge
1999 Dodge ram 2500..... 360 Automatic.
The truck will not start. UNLESS..... you dump some gas down the intake. Then the truck will start and run and drive just fine. If you shut it off at any point in time it will NOT start. UNLESS you dump some more gas down the intake. Once you give it that little primer shot you can drive it for hours........
The crank sensor, coil, computer were all replaced by the previous owner who got fed up with it.
Any ideas? Anybody?
Old 07-28-2013, 06:46 PM
Vehicle: 1999
Any ideas? Anybody?
im guessing that the injectors are supposed to pulse..... or cycle.. when you turn the key on..... I take it that's not happening and that's where the problem lies
Old 07-29-2013, 06:43 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
any idea what the fuel pressure is at before starting?
Old 07-30-2013, 05:33 PM
Vehicle: 1999
I personally did not check the fuel pressure... but the previous owner a friend of mine. bought a fuel pressure gauge just to check it... and he said it was fine. I think around 40lbs but I don't remember exactly
Old 07-30-2013, 05:51 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Next time try tapping on the tank while turning the key. The pump may not be building enough pressure.
Use a rubber mallet and let us know what happened.
Oh, by the way...Here's your crown KingNothing...
Old 09-11-2013, 02:21 AM
dabranco dabranco is offline
Vehicle: 1996 dodge ram
Color: red
dabranco is on a distinguished road
Sounds like a weak fuel pump to me. I would get a fuel pressure gauge and double check the pressure. Make sure your not dropping pressure as your trying to start.
Old 09-17-2013, 05:34 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Check to see if it holds at 40 psi for 5 mins. If it doesn't, you have a problem with the fuel system.
