Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 3.7L Slant 6 Specific Topics
Old 07-28-2013, 07:31 PM
luckybuff luckybuff is offline
Vehicle: 1987 D150
Trim Level: basic
Color: dark blue
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
luckybuff is on a distinguished road
Default First post first dodge 1987 problems!
Hello gang from Cajun Country!
Bought my first dodge. Slant 6 blown, ran hot, hole behind the starter. But! I have a 78' 440-1 stock plus 727 out of an RV, all parts re-usable. What in the heck do I have to deal with. 727 tansmission has a yoke and the s6 has spline. Wiring and vac will be different. Engine mounts should be avilable. So whats the hardest part besides sweat?
Old 07-28-2013, 07:54 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
does the 440 have a rear or front sump oil pan? does the truck have a computer behind the battery or on the air cleaner? if so you will have to convert to the 4 pin ignition system which should only cost about $100 since you should not need to replace the distributor. just have to buy the 4 pin ignition module, ballast resister and mopar wiring harness.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
