Old 07-28-2013, 10:39 PM
longhorn2012's Avatar
longhorn2012 longhorn2012 is offline
Vehicle: 2012 dodge ram longhorn
Rep:39
longhorn2012 is on a distinguished road
Exclamation HID lights stopped working
Hey guys i bought a set of HID lights from retro solutions
my fogs work no problem. all of a sudden my headlights dont work
what could be the problem? . had to use my highbeams to drive home from work
Old 07-28-2013, 11:48 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Both of them stopped working at the same time? I would say you've got an issue in your TIPM.
Old 07-28-2013, 11:50 PM
Rep:39
yea they both stopped working. fogs are working fine. cant get the headlights to come on. whats the TIPM
Old 07-28-2013, 11:57 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
If you used their relay setup that triggers off one side or the other to turn both on... you might want to check that first.
I've had a ground come lose on the relay that kills the entire system.
I highly doubt it's your TIPM because your fogs work.
Chrome... in moderation.
Old 07-29-2013, 01:02 AM
Asur Asur is offline
Vehicle: .
Rep:4373
As other have indicated it could be just a loose wire in your install, if your using a wire harness for those check that your relay is engaging, it as Arth indicated could be a ground, it could be a positive off the battery, it could be your trigger from the bulb connector that is not connected, it could be your relay in its socket is loose. You will need to trace the system to see where you issue is coming from. If your not comfortable tracing and testing your connections have someone who can use a tracer light or a volt meter or just a wire to manually trigger to see where your problem is coming from.
Old 07-29-2013, 12:57 PM
Rep:39
I will have to check tonight. All my cables and relay also ground
Old 07-29-2013, 01:27 PM
May have a loose wire, bad grounding or a locked up ballast that got corroded.
Same thing happened to me last fall and it was the drivers side ballast. Corroded like heck and it locked up (dead) and due to being relayed it caused the other to shut off.
There are many factors here.
Check the relay, check the connections in the ballast by removing the connections and check the ground.
Almost positive its the ballast or relay
Old 07-29-2013, 01:45 PM
bighemi04's Avatar
Rep:623
Yea check all of your connections before you go doing anything crazy. The dealer probably wont warranty the TIPM due to the HID's anyway
Old 07-29-2013, 01:58 PM
Check the other things before you get scared of it being the TIPM as there are many things to flake out before the TIPM
Old 07-29-2013, 02:15 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
1) Check the fuse.
2) Check the ground connections.
3) Check the relay.
4) Run a hot wire directly to the ballast from the battery.
Hope this helps.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
