Old 07-29-2013, 01:27 AM
dmac101 dmac101 is offline
Vehicle: 2012 dodge ram
Trim Level: laramie
Rep:39
dmac101 is on a distinguished road
Default any hid better or whats the best.
have some hids i got with my headlights, not sure on brand or anything i think they are 8000k just a guess, love the looks and output and everything but the passenger side light is clearly dimmer for some reason, so was going to order new ones. i see they range from like 35 to 150 on ebay why is this. whats wrong with the 35 dollar ones if their a xenon brand and such.
also what colour do u recommend was thinking either 8000 or maybe even 6000.
next and most important what does the 55 wat and 35 wat etc make a difference.
what like specificly do u recommend xenon 55 wat 8000 k? slim ballst or that dont matter?
Old 07-29-2013, 01:37 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Could be just your bulb is crapping out on you, might want to swap the bulbs from one side to the other to see if the problem follows.
As for price, you pay for what you get, and ebay you get most of the time something for nothing that will not last and be more an issue than anything, or you pay and get had. If your gonna spend the money on something as important as your front head lights, get a kit from a reputable company like Retrosolutions or the retrofitsource. JMO
5000k will give you your best light output, as you go higher in color you loose light output, 6000k will give you a small bluish tint
Its a truck, my recommendation is 55watt, wire harness made for your truck, 6000k you loose a bit of light output but its got a nice bluish tint to it and all that in a projector system, you can run HID in your regular headlamps but you will want to lower them a few degrees to not blind on-coming traffic since your housings will produce flaring if they are not projectors. Also places like Retrosolutions or the retrofitsource will usually have bulbs that the plasma ball is located pretty well at the same location your halogen filament would be, so you get a close match to your trucks proper reflector position.
Slim or not, thats up to you, you have a truck, lots of room for a normal ballast.
JMO
Old 07-29-2013, 11:18 AM
m00nraker's Avatar
m00nraker m00nraker is offline
Vehicle: 2013 RAM 1500
m00nraker is on a distinguished road
I have had nothing but tremendous luck with the kits from DDM Tuning.
I personally have had 5 sets from them between two trucks. The slim ballast kits are generally worth the extra $20 bucks, but for $50 for the kit I cant complain at all.
I understand retroshop and what he does, but I cant personally justify the extra money IMO
YMMV
Old 07-29-2013, 03:31 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Check the ground wire. Switch the bulbs from left to right. run a power wire from the battery to the ballast. You could have a ballast going bad.
5000K is the brightest and buy the bulbs in pairs so the color is the same.
You want 55 watt ballasts.
I would recommend 55 Watt ballast, 5000K Bulbs or 6000K Bulbs, Error code eliminators, wiring harness.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 07-30-2013, 08:01 AM
bendodge bendodge is offline
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
Default My fix for the Ram Headlights
I have spent a lot of time reading about all the ways to improve light output from the stock headlights. In the end I chose Retroshop custom projector headlights with HID bulbs.I am finalizing my order in the next few days and will post the questions and answers I had when making the decision on what lights and options to get.
