Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2013 Dodge Ram Forum
Old 10-24-2013, 09:45 AM
Badgeman57 Badgeman57 is offline
Color: Deep Cherry Red
Badgeman57 is on a distinguished road
Default Oil pressure readings
Hello all, I just recently performed my first oil change at 3000 miles on my 3.6l. On the dash read-outs the oil pressure SEEMS to be lower than before I changed the oil. I went with Quaker State full synthetic 5w20 and Microgard filter element. I really don't remember what the operating pressures were exactly, BUT I THOUGHT they were in the medium to above medium range on the digital bar gauge. The pressures are now way below that, in the 20-35psi range, and lower than that at idle. Is this range acceptable OR do I need to change to a different filter that possibly isnt as restrictive? But in doing that wouldnt that not be as efficient in capturing dirt particles? Any input is greatly appreciated.
Old 10-24-2013, 09:54 AM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016 4x4 Regular Cab w/8ft bed
Trim Level: Tradesman 4x4 w/3.92
Rep:974
Definitely get yourself a quality oil filter(i.e., Mobil1, Wix, Royal Purple, Napa Gold), just to name a few. Some say pressures between 15-20psi at idle, operating temp, is normal for a Hemi and some have reported seeing 7psi at a hot idle. Typically 50-70psi at/above 3000rpm.
Old 10-24-2013, 09:58 AM
OldJoe OldJoe is offline
Vehicle: 2013 Ram 1500 Quad Cab, 8sp
Trim Level: BigHorn. RamBox
Rep:217
OldJoe has a spectacular aura aboutOldJoe has a spectacular aura aboutOldJoe has a spectacular aura about
Just curious, but why not just stick with Mopar filters?
Old 10-24-2013, 10:06 AM
Gantman's Avatar
Rep:974
Mopars are good too as I keep one on hand, but, I just like when I remove my oil filters, that rubber oring stays attached to my old oil filter. But, to each his own my Grandpa always said.
Old 10-24-2013, 02:04 PM
I just get whatever is available at my local auto parts store. Oreilly, Advance Auto Parts, Auto Zone are here in Texas. They all carry Fram, Autolite, AC and the like. Is any one better than the other?? My truck is the V6 3.6L. I buy the oil at WalMart since it's cheaper than at the auto stores. And the cartridge filter snaps in to the screw-on cover on top of the engine. At highway speeds of 70MPH the pressure is still in the 20-35psi range. Can't get it to go to at least the 1/2 way mark on the dash digital readout monitor for a steady constant pressure, except on accleration, then always falls down below 1/2. Am I ok with this?
Old 10-24-2013, 02:13 PM
kxlexus kxlexus is offline
Vehicle: 2013 Laramie 4X4 Quad Cab
Trim Level: Laramie Hemi 8 Speed
Color: Maximum Steel Met.
Rep:25
kxlexus is on a distinguished road
I would let the dealer take a look at it
Old 10-24-2013, 02:21 PM
Asur Asur is offline
Vehicle: .
Rep:4373
If your leasing your truck for like 3 years it don't matter none, as long as you do your oil and filter changes as per the maintenance schedule. If you want to keep your truck for a long time, yes it does make a difference. Some filters are better than others, as some oils are better than others, on the long term that is where you will see the difference. Short term you don't care cause its not going to be your truck after 3 years.
