Old 07-29-2013, 01:07 PM
Antairus Antairus is offline
Vehicle: 2006 Ram 150 Hemi
Antairus is on a distinguished road
Default 100,000 Mile Maintenance
My 2006 Dodge Ram 1500 Hemi Has hit 103,000 Miles. I am wanting to take it in to have Preventive Maintenance done to it. My Question is What Exactly needs to be done? I know its a broad question. I'm thinking injector cleaning, new belt, new plugs, air cleaner, brake system flush. Does the timing chain need to be replaced?
Old 07-29-2013, 01:18 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
Shouldnt be any different than any other maint. interval. Chains generally dont get replaced, belts get replaced at about 100k. Honestly what needs to be done depends on what you have done on a regular basis.
Injector cleaning: Ok to do, but you should do that any time you feel the engine is getting sluggish
Belts: If you havent replaced them then go ahead, remeber to replace the tensioner too
Plugs: Depends on the last time you replaced them. If you havent then its a good idea
Brakes System: Should be flushed whenever brakes are replaced, not mileage dependant
Air, Oil, Etc: Keep replacing at your normal interval
Things you should consider doing if you have not already:
Trans filter change and fluid flush
Differential fluid change
Transfer Case Fluid change
Power Steering Flush
Check and inspect all steering components for wear
Inspect and replace parking brake if necassary
Inspect radiator/AC condensor for leaks/cracks
Change all hoses if necassary
Check torque on exhaust manifold bolts
Have your battery and alternator tested to make sure they are still in optimum range
I am sure I could think of a few more given time.
Spyntec Hubs, 35" Toyo AT II, Synergy Steering Brace, Fox 2.0 IPF. BullyDog Tuner, Katskinz Leather........................
Old 07-29-2013, 01:35 PM
Okay that's a list. I will work off that. I think I will do the First mentioned and Add the Trans flush to it. That ought to be a $600.00 Bill. Hey I want to get another 100k out of it.
Old 07-29-2013, 02:45 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:547
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
That's a good way to look at it. Even with all this maintenance you will still save money over buying a new vehicle.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread-removed), Matte black Plasti-dipped center console bezel, BT catch can, Corsa 14405 cat back.
