Old 07-29-2013, 03:14 PM
ramitdamit's Avatar
ramitdamit ramitdamit is offline
Vehicle: 2002 Dodge Ram Quad
Color: Atlantic Blue Pearl
ramitdamit is on a distinguished road
Default Aftermarket LED Tail Lights Acting Up.
I'm on my second Set of tail lights and they keep burning out With in a few months. Starts off with half the LED Panel burning out then the whole tail light. Not sure whats causing it. Spike in the Electrical system?
Old 07-29-2013, 05:13 PM
Asur Asur is offline
Vehicle: .
Rep:4371
What kind of rear tail lights did you Get? Make? How old? Are you getting them replaced under warranty from the seller you bought these from when they fail?
Old 07-29-2013, 10:31 PM
ramitdamit's Avatar
Ordered both sets from Xtralights. Spec D's Smoke LED's
They Both have acted up after the warranty is up. First set after 5 months and this set now its been around the same amount of time.
Old 07-29-2013, 10:35 PM
ramitdamit's Avatar
Haven't Tempered with the factory wire harness. Still all factory and I don't have a Trailer Harness on it.
Old 07-30-2013, 02:43 PM
Vehicle: .
Rep:4371
All I can say is it sucks, would have to check what others have said about these products, I run a 600 lumen LED Bulb in my tails, strong as hell and have run them for over 8 months no issues. I will look into these and see what I can find about them.
Old 07-31-2013, 04:35 AM
Coastiejoe's Avatar
Coastiejoe Coastiejoe is offline
Vehicle: '11 Ram 1500
Color: Silver/Gray
Rep:37
Coastiejoe is on a distinguished road
Are you getting hyperflash? Most cars think LED's are a burnt out bulb and will make the lights blink super fast. That could be the cause of the boards burning out. The only fix is to buy a replacement electronic flasher/relay if you can find the original one. (Some cars also use the computer to flash the signals so that may be out of the question.) Or install some resistors in parallel with the circuit at each bulb.
