Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Drive Line
Drive Line Ball Joints - Wheel Bearings - Shocks - Springs - Alignment etc.
Old 07-29-2013, 10:16 PM
docdave78 docdave78 is offline
Vehicle: 2004 Dodge Ram QC SLT 4x4
Color: Deep Molten Red
docdave78 is on a distinguished road
Default Axle overheating
I have an 04 Ram QC 4x4. My passenger rear axle housing is hot to the touch after sitting about an hour. The rim is also burning to the touch. I get a burning smell too, either rubber or electrical smelling. The other axle is cool to the touch and the rim is warm, but not burning. I haven't used my e-brake in a while s that's not locked up. Any suggestions?
Thanks
Old 07-29-2013, 11:52 PM
DRX350's Avatar
DRX350 DRX350 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
Check the brake for signs of wear, that's the first thing.
Beyond that, maybe check diff. fluid level...
Old 07-29-2013, 11:59 PM
Lobo Lobo is offline
Vehicle: 2013 Ram
Color: Grey
Rep:14
Lobo is on a distinguished road
I'd suggest checking for a brake dragging or bad wheel bearing. Jack the wheel up and spin the tire by hand. If it's the brake you should be able to feel drag on the wheel that most times will vary as the wheel is turned since most rotors or drums will have a high spot. Usually, a dragging brake will discolor (as in blue versus shiny) the rotor surface. If it's the bearing, it will usually make a steady grinding noise. Good luck, Lobo.
