Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
tonneaucovered.com
Old 08-09-2013, 11:02 PM
scrubby scrubby is offline
Vehicle: 1993 W-150 v-6 1992 D150 v-8
Trim Level: bace and LE
Color: 93 gray 92 maroon / gold
Engine: 1992-1991 239ci (3.9L) Magnum V6 180hp
scrubby is on a distinguished road
Default motor swap computer question
I have a 1993 Dodge ram w150 with the 3.9l v-6 with a automatic in it . I am in prosess of swaping in a 360 maguim 5.9l v8 with a grany low 4 speed behind it. I have had a hard time finding a pin out diagram on these computers to tell me what each pin does and where it is located. I have the Part Number: NEC XTP97832 Product Line: NAPA Reman. Computer in the truck now, I am trying to find one that will plug in with little modifications other than the 2 new injectors that need to be run from what I understand this is easly done by plug and play ? I have a 98 motor and computer I can swap in but am relictent to do so because I would have to sclice and dice the wiring.
Old 08-10-2013, 03:32 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 08-10-2013, 06:05 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:93
Save yourself some headachjes and get a pre-'96 360 Magnum computer. Your V6 harness will plug in and all you'll need to do is run the two injector wires.
Old 08-10-2013, 06:38 PM
That is my plan to use a pre 96 computer but do yall know witch one will work? I was looking at a computer from a 94 ram 360 the plug looks the same but is the pin outs the same ? Thank you crazzywolfie for the image, is this the v-6 or v-8 pin out thanks again.
Old 08-10-2013, 09:33 PM
that is for both v6 and v8 trucks.
Old 08-10-2013, 09:41 PM
ok so what years is this fit? I have a 93 and I was thinking of using a 94 computer, Is the wireing the same? I know the midsize are the same harness v=8 to v-6 but the full size is the same ? Thanks again for your help.
