Old 07-30-2013, 12:07 AM
murdermase15 murdermase15 is offline
Vehicle: 2001 Dodge Ram
murdermase15 is on a distinguished road
Default Leveling Kit Advice
I own a 2001 Dodge Ram 1500 and I am looking at installing a TGC 2.5'' leveling kit and was wondering if I will need to install blocks on the back? I have asked around and some people say that I will need them and some say that I wont? Also, if anyone knows the rake of the vehicle that would also be appreciated. Thanks!
Old 07-30-2013, 03:20 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
Every vehicle is slightly different from the factory. If you want to know your rake, go out and measure it.... that way you know exactly what your numbers are and what set up is going to work best on your truck.
Measure all 4 fender heights. From there you can find out your rake at stock height and how much rake you'll have after installing the 2.5" level. You'll want to retain at least 0.5" of rake to avoid looking nose high. If you have less that 0.5" of rake after the leveling kit then you can add rear blocks.
Old 08-09-2013, 01:55 AM
Sull Sull is offline
Vehicle: 2011
Sull is on a distinguished road
Bilsteins 5100 have the best feedback and I couldn't be happier. Went from 36 1/2 to 39 1/2"
