Old 07-30-2013, 01:04 AM
Garemz Garemz is offline
Vehicle: 2015 Ram Sport
Rep:12
Garemz is on a distinguished road
Default 305/55/20 Toyo AT2 Extreme
Will these tires give a lot of road noise, worse ride,worse gas milage?
http://www.westkycustoms.com/product...-20-Tires.html
Old 07-30-2013, 05:45 AM
KPSRQ's Avatar
KPSRQ KPSRQ is offline
Vehicle: '13 1500 Sport
KPSRQ is on a distinguished road
With it being E rated, they're going to be really heavy. My D rated 35" General Grabbers on my Jeep with the rim were about 120lbs per tire, the tire alone was 88lbs. An E rated is designed for heavier loads therefore has more Plys. You won't get better gas mileage with more unsprung weight.
The ride also won't be better than what came stock, probably a 'C' rated tire, since there's more Plys it'll have less give to bumps on the road. You can combat this by getting some better Fox or Bilstein reservoir shocks but that's an extra $900.
Old 07-30-2013, 07:21 AM
DAA DAA is offline
Vehicle: 2013 1500, CC/6'4", Hemi/8 spd
Trim Level: Longhorn
Rep:352
DAA is just really niceDAA is just really niceDAA is just really niceDAA is just really nice
Stock are P rated. No LT tire is going to be as light, ride as nice, or give as good of MPG as the stock tires. But then again, no LT is going to be as pitifully weak and totally worthless on a pickup as the stock P crappers either. Those tires that come on the new 1500's should be an embarrassment to Ram.
- DAA
Old 07-30-2013, 04:20 PM
Spike Spike is offline
Vehicle: 2013 RAM Big Horn 4x4
Rep:58
Spike will become famous soon enough
I lost 1-2 mpg with my Falken AT's (see sig). They do ride a little rougher than stock but not bad. No difference in road noise. 10 ply = no flats in the mountians and deserts...or at least it is rare.
Past: '13 Lifted RAM and lots of Jeeps
Future: '17 RAM 2500 MC 4x4
German Shepherd co-pilot
Old 08-13-2013, 09:45 PM
Rep:12
with this tire size over the factory tire size, will the mud flaps need to be removed?
Old 08-15-2013, 01:22 AM
Rep:12
Anyone? Anyone ?
Old 08-15-2013, 08:45 PM
bouf0010's Avatar
bouf0010 bouf0010 is offline
Vehicle: 2013 Dodge Ram 1500
bouf0010 is on a distinguished road
i still have my mudflaps with 305/55R20s, is your truck leveled?
T-1000 HF 93 Tuned - S&B CAI w/custom air scoop - Moe's 87mm tb - Silver Ceramic JBA Shorties - Magnaflow Y-pipe - GT Custom 22" muffler - V6 E-fan mod - 180 t-stat - Catch Can - bielstein shocks - 2" rear drop coils - Cooper Zeon LTZ 305/55R20
Old 08-16-2013, 09:34 AM
Rep:12
Levelled? Lie a lift kit? No it's all stock
Old 08-16-2013, 09:49 AM
bouf0010's Avatar
I would highly recommend a leveling kit if you want that big of a tire. Youre going to run into a lot of rubbing issues if you dont.
Old 09-06-2013, 10:56 AM
bouf0010's Avatar
well, i think ive proved myself wrong. I put my truck back to stock up in the front, and my 305/55R20 tires arent rubbing whatsoever!
