Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 07-30-2013, 08:14 AM
KH85 KH85 is offline
Vehicle: 2006 Dodge Ram 1500
KH85 is on a distinguished road
Default CEL Flashing...Stutter at low throttle
Greetings all, I'm new to this awesome community. As I'm googling my symptoms, I kept running into this site so I figured I'd go ahead and join. There's a lot of great info and great people on here. Glad to be a member, and I hope I can contribute.
I'm having an issue with my '06 Ram 1500 (4.7L). My gas mileage went way down, so I changed all the spark plugs and even changed all 4 O2 sensors. Once I was done, I disconnected the battery and waited a little bit before re-connecting it. I didn't drive it the rest of the day, and it ran fine to work the next morning. However when I got back in it later that morning, it started stuttering really bad as I was pulling out of my parking spot and the CEL started flashing.
I put it back in my parking spot and started my googling to see what it could be. Long story short, at the end of the day the CEL went solid so I was able to drive it to Advance Auto to get a diagnostic. I notice that it only stuttered when I barely had the throttle open (so I'm figuring something with the air flow). Here are the codes that I received at Advance:
P0300: Random Misfire
P0138: O2 Sensor High Voltage 1/2
P0133: O2 Sensor Slow Response 1/1
P0153: O2 Sensor Slow Response 2/1
P2096: Post Cat Fuel Trim too lean Bank 1
P2098: Post Cat Fuel Trim too lean Bank 2
I got home and disconnected the battery for about 15 minutes, and went back out. I started it up and of course the CEL was off because it reset. The truck actually ran fine until I got to my turn around point about 1.5 miles from my home. It started stuttering again, and the CEL started flashing. I limped it home and parked it. Before I turned it off, I could hear something "knocking".
I'm pounding my head against the wall and don't know where to start. Any help would be appreciated.
Old 07-30-2013, 09:42 AM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
I was just reading a post on a Chrysler forum about someone having just changed their spark plugs and O2 sensors because of noticed drop in MPG. He started getting P2096 His problem was inferior quality O2 sensors. Did you replace your OEM o2 sensors with Bosch? Do you still have the old O2 sensors?
Old 07-30-2013, 10:55 AM
I put Bosch o2 sensors in it. I suppose I could put the old ones back in and see if the problem is still there.
Old 07-30-2013, 11:32 AM
Color: Mineral grey
Rep:109
Yeah i'd swap them and see what you get. I mean before replacing them you weren't getting any codes?
Old 07-30-2013, 04:14 PM
A few months ago I would randomly get codes dealing with my o2 sensors but they would go away. I wasn't getting any misfiring like I am now. I figured since I was getting bad gas mileage I'd do the spark plugs and o2 sensors at the same time. I've heard that the tips are really sensitive if they touch anything. So I'm concerned the old sensors may be jacked up since I just took them out an threw them in a plastic bag.
Old 07-31-2013, 10:43 PM
Sure enough, I put the old O2 sensors in and it's back to running normal; however, I now have some rattling in my cats, so I'm going to start researching if I need to replace them. Any advice?
BTW, just the new spark plugs made my MPG jump from 13 to 16.
Old 07-31-2013, 10:51 PM
deanhinsley1963's Avatar
deanhinsley1963 deanhinsley1963 is offline
Vehicle: 2004 Dodge Ram 1500
Color: silver
Rep:12
deanhinsley1963 is on a distinguished road
KH85 How many miles do you have on the truck? Mines got 104,000 I just bought it and dont know if they have been changed or not. But I dont get but 14mpg.
Old 07-31-2013, 11:04 PM
Color: Mineral grey
Rep:109
they should be fine as long as there's no oils or water on them.
I mean I'm not saying leave them in permanently. If you see better results with the old ones back in get NTK brand o2 sensors.
Old 08-04-2013, 03:40 PM
Mine just turned 105k. After changing the plugs and putting the old O2 sensors in, I ran it up from NC to OH and got 16 mpg. My CEL came back on with the P0430 code (Bank 2 Cat below threshold). I'm hoping that replacing my cats/exhaust system to high flow will help it even more. I also will have my new K&N Cold Air Intake waiting on my porch.
