Old 07-30-2013, 11:49 AM
CraigDG1029 CraigDG1029 is offline
Vehicle: 2008 Dodge Ram
Trim Level: Big Horn SLT
Color: Khaki-ish, tan-ish, gray-ish
CraigDG1029 is on a distinguished road
Default Stacked leveling kits?
I would like to start out by saying I believe this is a terrible idea. But my
Mechanic who is a family friend of over 30 years and a very knowledgeable guy, overheard me talking about how I'm not a fan of the rake on my truck. It's got 2" blocks in the back and a 2.5" coil spring spacer kit up front. He suggested I get a 1" bottom coil spring spacer to add on to level the truck out some more. I think it's a terrible idea and I'd be better off buying 2500 coil springs and shocks and adding a 1" level to that. Anyone have any ideas on how to get the front up to 3" or 3.5" total without having to buy an entirely new lift kit?
Old 07-30-2013, 11:56 AM
Crux420's Avatar
Crux420 Crux420 is offline
Vehicle: 2012 Outdoorsman 1500
Trim Level: Outdoorsman SLT
Crux420 is on a distinguished road
Anything over 2.5" of lift will start to cause excessive wear on your cv's, ball joints, etc. if your wanting more than the 2.5" your probably gonna have to go with either a proper lift kit or you can look into a small body lift. Personally if you don't like the rake now I'd try removing the rear block, see if it improves the stance and if you still want more height then try the body lift. Hope this helps, good luck
Old 07-30-2013, 04:41 PM
dodge.ram dodge.ram is offline
Vehicle: 2006 Dodge Ram
dodge.ram is on a distinguished road
I've been running that exact set up for 2 years never had a problem.
Old 07-30-2013, 07:41 PM
you have been running a 2.5" and a 1" combined (top and bottom) on your truck?
Old 07-30-2013, 08:38 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
i suggest save up and do it right. not jerry-rigging kits together. Your truck will thank you for it in the long run.
not many people suggest combining kits like that.
Old 07-30-2013, 09:27 PM
EXPRESS25C's Avatar
EXPRESS25C EXPRESS25C is offline
Vehicle: 2012 Dodge Ram Express RCSB
Trim Level: RCSB - Express 25C
Color: Diamond Black
Rep:83
EXPRESS25C will become famous soon enough
I agree totally.
"Excess is Best"
Old 07-30-2013, 09:45 PM
Trim Level: sport
Color: green
Rep:652
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
not something i would do with my jeep, so i wouldn't do it on my truck. costs more but a proper lift kit will save some components and help the truck handle close to stock, depending on how high you go.
Old 07-30-2013, 11:15 PM
Sorry read your post fast- I'm running a 2" top and a 1" bottom spacer.
People get scared about this kind of thing but think about it- if guys will put a 3" top spacer in why is it any more risk to put a 2" top and 1" bottom?
To me it would seem safer because at least on my 2wd truck the top spacer pushes the spring further down out of the upper coil spring bucket- more chance for it to fly out?
Of course the whole idea of a 3" spacer is not the best for your truck in general because of ball joint angles ect. but I don't see a safety issue there.
