2001 5.9 hesitation/backfires - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-30-2013, 11:29 AM
STOMPER72 STOMPER72 is offline
Vehicle: 2001 Dodge Ram 1500 4x4
Color: Blue
STOMPER72 is on a distinguished road
Default 2001 5.9 hesitation/backfires
Hey fellas...
I have a 2001 Ram 1500 5.9 4x4 107k miles. I'm experiencing hesitation and backfiring under acceleration. This is the background on the truck it might not seem related but bear in there.
A few weeks ago I rebuilt the front axle. New hubs/bearings, u-joints, right and left seals, and the 4x4 actuator. The above problems happened instantly after I finished the front end. So I replaced the cap, rotor, coil, plugs, and ignition wires. Started the truck and idled fantastic. Drove it and it ran like a boss until I stopped for a red light. When I accelerated the truck fell on its face once again. Hesitation and back firing. My next step is to check fuel pressure.
HAVE ANY OF YOU HAD THIS PROBLEM?
Thanks in advance!
Old 07-30-2013, 12:29 PM
DRX350's Avatar
DRX350 DRX350 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
Replace the TPS (like $35), mine did that, eventually it will get to the point where it only idles and if you try to accelerate you'll be popping like crazy with NO power...
Old 09-10-2014, 12:49 AM
chadknight71 chadknight71 is offline
Vehicle: 2001 Dodge Ram 1500 Sport 4x4
Trim Level: Sport 4x4
Color: Grey / Silver
chadknight71 is on a distinguished road
I have a 2001 Dodge Ram 1500 Sport 4x4 5.9 Magnum. The problem i am having is that when i start it up and leave it at idle it has a small miss about every 5-7 seconds. Plus when i put it under load it still has a miss and then i get a small backfire through the throttle body. Any solutions???
Old 09-10-2014, 03:35 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2014 1500 Eco diesel/1982 D150
Trim Level: Outdoorsman
Color: Deep cherry red
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:21
Check and see if vacuum acurator on front axel is hooked up.
