Power wire into cab - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 07-31-2013, 01:47 PM
firemarshallvin's Avatar
firemarshallvin firemarshallvin is offline
Vehicle: 2013
Trim Level: Laramie Longhorn
Color: Black Gold Pearl
firemarshallvin is on a distinguished road
Roger that everyone. I may have miss spoken, don't know why I said a #4, prob closer to a #8, which I may reduce even more based on what I have.
@jdftwrth - I believe that this is the guy...
http://www.galls.com/galls-six-function-switch-box
2013 RAM 1500 Laramie Longhorn - Black Gold Pearl with all the trimmings. HEMI, 3.92, 8-Speed and Air Suspension
Add-ons:
14" Magnaflow, BAK FiberMax Tonneau, Misc Whelen Emergency Lights and Switchpak, 275/60R20 - BFG T/A KO2
Old 07-31-2013, 03:08 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I was able to get (2) 12 gauge wires through the nipple using a little lube to help the wires slide. 1 wire for hot and 1 wire for ground. I wanted this for my CB radio that I installed and I didn't want to use a frame ground. Pretty much filled the hole.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 07-31-2013, 04:29 PM
oxco oxco is offline
Vehicle: 2013 Ram 1500 Longhorn
Trim Level: Longhorn
oxco is on a distinguished road
If you have a 7 pin trailer hitch splice into that for both your hot and ground. I have Recon bed lights, ran the wires along the upper rail into the holes in the back and down under the truck. I put a fuse between the hot wire in the hitch and the switch. I put the on off switch in the hole on the lower back of the bed on the driver side. Works great.
